Comtemplating the 2.35:1 screen... - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
post #61 of 88 Old 01-31-09, 08:45 PM Thread Starter
Re: Comtemplating the 2.35:1 screen...
Can spray adhesive be used on it to apply it to the wall... or is it too porous and thin? After all, you did mention spongy. I was thinking about maybe doing the entire front wall in it... maybe over some 705 or similar.
Sonnie is offline
post #62 of 88 Old 01-31-09, 09:08 PM
Mark Techer
Umm, the stuff I have is self adhesive like the "contact" that you cover books in, except that it is flocking, not plastic...but the same deal, peel away the backing and then stick it on the clean surface.
I did use spray adhesive for foam tiles though, but found that double sided tape worked better there too...
Mark
Mark Techer is offline
post #63 of 88 Old 01-31-09, 10:43 PM Thread Starter
Where in the USA might one find this stuff that you use? Does it have a specific name?
Sonnie is offline
post #64 of 88 Old 01-31-09, 11:36 PM
Mark Techer
I don't know given that I am in Australia...
Mark
post #65 of 88 Old 02-01-09, 10:31 AM
Rodny Alvarez's Avatar
Rodny
Is this the same thing?
last one on the page
http://www.mcmaster.com/#88015k1/=ex202
Rodny Alvarez is offline
post #66 of 88 Old 02-01-09, 05:07 PM
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
Sonnie wrote: View Post
In Australia you can buy 3" wide self-adhesive rolls of the flock tape from ebay..
You might find the same thing over there..
Prof..
Home Theatre...the never ending story!
Prof. is offline
post #67 of 88 Old 02-01-09, 06:26 PM Thread Starter
I am going to need something wider than 3" for covering the front wall.
I might order some of the Fidelio velvet and some of that self sticking velvet that Rodny posted a link to, and see how they compare.
Sonnie is offline
post #68 of 88 Old 02-01-09, 08:49 PM
Prof.'s Avatar
The Mad Professor
I think we're talking about three different things here..
For the screen borders, you will need to have them covered with Fidelio velvet or the flock adhesive tape,.,.
If you are planning to cover the front wall around the perimeter of the screen, then you don't need to use the Fidelio velvet..
Any good black velvet or velveteen will be fine...There won't be any light spill on that area..
If you're looking at a screen wall, with speakers mounted behind it, then you will need to use something like GOM or an open weave material..
Prof..
Prof. is offline
post #69 of 88 Old 02-01-09, 09:44 PM Thread Starter
No speakers behind anything.
Do they make Fidelio velvet in 3" widths with the adhesive backing?
Sonnie is offline
post #70 of 88 Old 02-01-09, 09:53 PM
Prof.'s Avatar
The Mad Professor
Not that I'm aware of..
I believe Joannes have..or used to have Fideliio velvet..They should be able to tell you if it's available in stick-on rolls..
Prof..
Prof. is offline
2.35:1 , comtemplating , screen...
