Optoma HD20 - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
post #41 of 66 Old 10-08-09, 05:55 PM
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
Re: Optoma HD20
custard wrote: View Post
quite ugly looking but it works!
Simple but effective custard..
I use the same idea with my HD65, only I have compression springs between the projector and the top plate..
Prof..
Home Theatre...the never ending story!
Prof. is offline
post #42 of 66 Old 10-08-09, 05:58 PM
rmerlano
Re: Optoma HD20
Prof. wrote: View Post
I agree!
What about of PICS the movies in FullHD of King Kong, Dark Knight, Casino royale, Transformers...
rmerlano is offline
post #43 of 66 Old 10-08-09, 06:06 PM
rmerlano
Re: Optoma HD20
Custard, more homework!!!
Do you have the posibility/choice of project an image of 150"??
rmerlano is offline
post #44 of 66 Old 10-09-09, 01:37 AM Thread Starter
custard's Avatar
custy
Re: Optoma HD20
rmerlano wrote: View Post
i'm sorry but i can't - i am limited by the width and and depth of my room to the size mentioned before.
here is an album from a uk user of the hd200x which is pretty much the hd20 in a black casing.
i dont think i will be able to take pics to this standard...
http://www.apah20.dsl.pipex.com/hd200/
custard is offline
post #45 of 66 Old 10-09-09, 01:49 AM Thread Starter
custard's Avatar
custy
Re: Optoma HD20
the compression springs is a great idea.
i had considered using some more wingnuts underneath the plate aswell to provide similar stabilty to the springs you mention. the unit works fine without so i have left as is.
just though that i would mention that the lower plate of the two has holes about 5cm wide to allow for minor movement of the top plate and PJ horizontally and forwards/backwards.
custard is offline
post #46 of 66 Old 10-09-09, 09:10 AM
rmerlano
Re: Optoma HD20
Ok, no problem, I understand the limitations.
About the pics of UK user, them look great!!!!!
Do you know the screen size of him? or do you know how to contact him?
Thank you for your help?
rmerlano is offline
post #47 of 66 Old 10-09-09, 12:35 PM Thread Starter
custard's Avatar
custy
Re: Optoma HD20
i cant remember the exact size but its smaller than mine so i think that does not help you.
as i said before the hd20 will work for you if you are happy with the brightness of the hd65.
custard is offline
post #48 of 66 Old 10-09-09, 05:53 PM
Prof.'s Avatar
The Mad Professor
Re: Optoma HD20
That idea might just solve my problem!.
With an anamorphic set up, it's very difficult to fill the scope screen without using any zoom, if the projector is not quite exactly the right distance from the screen..
It only needs that small amount backwards or forwards to get the exact position..
At the moment I only have a single plate above the projector, so adding a second plate with large holes, will give me that fine adjustment!
Thanks for the idea custard..
Prof..
Prof. is offline
post #49 of 66 Old 10-12-09, 11:07 AM
rmerlano
Re: Optoma HD20
I dont see any dissapoint about it!!
Im happy to help you hehe
Custard, did you do your homework??
rmerlano is offline
post #50 of 66 Old 10-12-09, 12:23 PM Thread Starter
custard's Avatar
custy
Re: Optoma HD20
not yet.....
do you still need some images or are the photos from the earlier link enough for you?
custard is offline
hd20 , optoma
