1st Projector advice - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 18 Old 10-28-11, 09:50 PM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
Hey all!
I have been reviewing the projector forum, reading reviews, and using the projector calculator to try to determine my options for projectors.
I have a room that is 14x21x7.5, fully able to control lighting, and plan to use it mostly for movies but will also do some sports and a Wii.
The screen size will be 92" diagonal. There are 2 rows of seating - at 8.5' and 14.5'. I am planning to do a projection room that will put the throw distance at @19'.
Putting all those parameters into the calculator, it looks like my best option is the Epson 8350 which gives me 16 Fl at a minimal zoom.
I am just wondering if anyone has any suggestions for other projectors that would work for my set-up. My budget would be for $2000 or less.
Thanks in advance!!
ALMFamily is offline
post #2 of 18 Old 10-29-11, 10:08 PM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
Re: 1st Projector advice
Thanks a lot Mechman!
post #3 of 18 Old 10-29-11, 11:14 PM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
Sorry, Mechman, I should have asked a follow-up question right away as well - given all those parameters and a Epson 8350 projector, do you have any recommendations for a screen?
Thanks!
post #4 of 18 Old 10-31-11, 01:04 PM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
Hmm... I should also have added that I am looking at a fixed screen.....
post #5 of 18 Old 11-03-11, 10:19 AM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
I am starting to waffle a bit on building that projector room at that distance - it seems like it will lock me in to a very small sampling of projectors that are capable of projecting to a 92" screen from that distance while maintaining an optimal Fl level.
Would I be better off ceiling mounting the projector closer or am I just overthinking this?
Any thoughts / opinions?
post #6 of 18 Old 11-03-11, 08:29 PM
Ryan
Will ceiling mount work for you with 7.5' ceilings? If your 2nd row is elevated, it might be an annoyance or a problem.
If it does work, I agree it gives you added flexibility in the future. In addition, on the long zoom projectors (like that Epson) you'll get more light at the wide angle end of the lens, sometimes significantly more (i.e. up to 45% light loss from max wide to max telephoto).
Placing the projector closer and higher will give you more room to play Wii without getting in the light beam too. Since you're looking at a 92" screen, you can place it quite close (on the order of 9' and a few inches if you wish). Please note it's often stated the a lens does not give its best image quality at either end of its range. This may or may not be visible.
I would expect the potential downside (as it will be closer) is more noticeable fan noise. On this Epson, that should not be a concern unless you are particularly sensitive to it. On the upside, it should get excellent ventilation if hung from a mount (vs. placed in a box).
Consider aesthetics as well - my significant other would likely prefer a rear shelf mount over ceiling mount for example.
Edit: I believe the Panny AE4000 just fits your budget too. It will look better in controlled lighting conditions than the 8350 (i.e. it has better blacks) and has lens memory if you're considering zooming for wide aspect ratio films. It also has frame interpolation which many like for sports. It's brightest mode is slightly dimmer than the 8350 but that should not be an issue on a 92" screen, especially if you mount it close to the screen. Those trade-offs may or may not be worth the extra $7-800 to you.
Since you mentioned gaming, make sure to check into the lag of each projector you consider. Depending on the game type, it can be a problem.
NegativeEntropy is offline
post #7 of 18 Old 11-03-11, 09:23 PM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
Thanks for the reply Ryan!!
You are correct - I have 7.5' ceilings. I was hoping there was a ceiling mount that allowed for a projector to not drop as far, or I could potentially start the mount inside the ceiling and build in a backer box.
Alternatively, since my second row of seats is at 14.5', I thought I could mount it right behind the 2nd row and not interfere too much with the seating or walkway behind the seats. That would at least move the projector to about 15' and give me a few more options.
Are there any other options I am missing?
post #8 of 18 Old 11-04-11, 11:13 AM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
After spending some time last night reading reviews and playing with Projector Pro, I am considering upping my projector budget.
If I go to 15' for the projector and ceiling mount it, the Panny AE7000 looks like it would be a good fit and received glowing reviews. It has all the functions / features of the AE4000 as well as 3D capability. Are there any other projectors in that price range I should consider?
As far as the low ceiling, it looks like Chief makes a ceiling mount that can be mounted flush with the ceiling. If it is mounted flush, are there any concerns from a cooling /noise standpoint I need to consider?
Thanks for any input!
post #9 of 18 Old 11-04-11, 10:33 PM
Ryan
What features/performance area are most important to you?
My knee jerk reaction is to suggest waiting on reviews on the forthcoming replacement for the Epson 8700UB, the 5010. But, again, it depends on your preferences. Me, for example, I have very little interest in 3D and as such, while I like the added brightness of the AE7000 over its predecessor, I am finding the $1000 price jump hard to swallow.
There should be no problems in flush mounting it - just verify the vents are on the front/back/sides on whatever projector you decide on. The manual should indicate minimum required clearances.
Noise (in terms of placement) should be mostly a function of distance and direction from the fan exhaust to the ears of the moviegoers (all else being equal). As such, a projector with front intake/exhaust should be quietest if it was in front of all seats, for example.
Since the Panny and Epson projectors have caught my eye the most, I'm largely ignorant of the DLP or LCOS options. I'm guessing they would mostly require mounting closer to the screen to net a 92" image as their zooms tend to be less than Epson/Panasonic's 2.0:1. I assume the room geometry is what's setting the 92" screen size?
post #10 of 18 Old 11-04-11, 11:37 PM Thread Starter
HTS Moderator
ALMFamily's Avatar
Joe
Thanks again for the reply Ryan!
After talking with the family more about what they want, the kids gave me a "wow, we could do 3D?!" So,I do actually have an interest in doing 3D, but will probably be mostly 2D. Beyond that, it looks like most of the features of the 7000 are similar to the 4000 with a few exceptions like light output (as you mentioned already). I do also like the 7000's ability to do 16:9 and 2.4:1 content easily as well as a good sports-watching experience.
Any idea on the time frame for the 5010?
And, yes, the room dimensions pointed me toward a 92" screen. After some discussion with Bryan about acoustics, I set the 1st row distance at 8.5' and it just seemed like going any bigger would be overwhelming from that close. Also, it gave me more room to move the front speakers away from the walls.
1st , advice , projector
