The Epson LPE Filter. Over 1600 Color Correct Lumens Out Of the 5010/5020 6010/6020? A Detailed Review. - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
post #41 of 52 Old 12-26-12, 03:46 PM Thread Starter
Nak
Re: The Epson LPE Filter. Over 1600 Color Correct Lumens Out Of the 5010/5020 6010/6020? A Detailed Review.
BTW, I watched the Imax Grand Canyon movie last night in 3D on my 138" white screen. Gain is probably around 1.0 to 1.1? I found the picture pleasantly bright, and I'm sensitive to dark pictures. I was using 3D Dynamic and the LPE filter. Colors seemed natural and skin tones all seemed natural as well. I thought the picture was gorgeous, even though I have not done a 3D calibration yet.
Nak is offline
post #42 of 52 Old 12-26-12, 07:11 PM
Banned!
Steve Mechelke -mech
Nak wrote: View Post
Well, that didn't work so good. I used the panel of rolled Glidden Diamond 450 that your sample was cut off, so you'd have an identical sample. here's the readings: 246, 246, 243 for the Glidden, 28, 16, 26 adding the LPE filter on top of the Glidden.
What I'm thinking is to use my diffuser and take a reading off of the PJ. I'll use a 100 IRE white field and adjust the PJ for perfect neutral. Then take a reading with the filter. How does that sound?
Yeah that makes a lot more sense. I forgot that the light had to get back through the filter a second time.
I guess the first readings I took would work better if you were measuring filters at a store. The light is going through the filter twice, which accounts for the very low readings. If you got identical readings off of a filter using the Glidden rolled sample, it should be a match. BTW, I initialized the i1 Pro just prior to taking the sample.
Edited to Add: Not sure how well the measurements are working. I'm getting pretty different results every time I measure. The problem is there's a lot of light being released on the "through the filter" shots. I tried throwing some black velvet over the whole thing, but it only helped a little. I think there's reflections from the frame and the filter getting mixed in with the measured light. Also, I get slightly different results off the Glidden if I move the sensor around. Small differences to be sure, but they are there. I get identical shots with Glossy Epson Photo Paper each time.
Minute differences are to be expected. As long as they aren't crazy different.
mechman is offline
post #43 of 52 Old 12-26-12, 10:48 PM Thread Starter
Nak
i1 Pro with diffuser taking readings facing the projector.
Without Filter: x=.3125, y=.3297
With Filter: x=.3226, y=.2988
Nak is offline
post #44 of 52 Old 12-27-12, 05:47 AM
That's quite a difference!! As they usually say in Star Trek....you have to compensate Nak!!
Yiannis1970 is offline
post #45 of 52 Old 12-27-12, 01:02 PM Thread Starter
Nak
3D Calibration added to Post #5.
@ Yiannis: LOL those are just numbers to help identify the color of the filter itself.
Nak is offline
post #46 of 52 Old 12-27-12, 04:18 PM
Banned!
I thought the filter corrected things?
Did you use a 100% white image? If so try it with an 80% white image.
mechman is offline
post #47 of 52 Old 12-27-12, 06:39 PM Thread Starter
Nak
Yeah, that was a 100 IRE image. I adjusted THX mode as close as I could to dead white. I saved that reading and then put the filter on and read that. I figured it would be possible to determine the tint from that. It translates to a RGB value of 255, 214, 244 or very close thereabouts. Now, how you determine the proper opacity is beyond me. I guess I should have written down the "Y" values as well... Or could you use the calculated Y off of BabelColor? I got this just by moving the pointer around the CIE diagram till it read the right xy coordinates. At any rate I think it worked out OK, eyeballing it that looks like the right tint.
The Epson LPE Filter. Over 1600 Color Correct Lumens Out Of the 5010/5020 6010/6020? A Detailed Review.-babel-lpe.png
Nak is offline
post #48 of 52 Old 12-27-12, 07:41 PM
Banned!
Cool. That should help.
mechman is offline
post #49 of 52 Old 12-27-12, 08:15 PM
mdp
Looks very nice. Wonder whether this will work with 3010.
Anyway, still no luck in finding the filter separate in Europe. I have the google alerts setup. But almost all those alerts are about this thread and the avsforum thread. let's hope something shows up.
mdp is offline
post #50 of 52 Old 12-31-12, 11:12 AM
Banned!
Does the filter look similar to this one in color?
mechman is offline
1600 , color , correct , detailed , epson , filter , lpe , lumens , review
