Im looking for a great recommendation for a projector for our first in home project. i was hoping to stick around $2k for it. Can that be done and still get quality? My whole project I have set aside about $5k to give this a go. id like to be atleast 100in from 9-10ft range if not 125in screen. I need clarity and quality. Limited light in the background due to overhead lighting so no one kills them self walking to my stairs. I can black the light out from the windows and keep it to a very low minimum. I watch movies, TV, and fights on it. Any help is appreciated. Im hoping to take advantage of some black friday sales if possible.
Ive installed several of these and they are stunning when properly setup.... They do have 4k up-scaling and a highly advanced display configuration and vertical / horizontal lens shifting / focus / zoom .... many others....
My clients still call me and rave about it months after installing.... Ive seen the Epson 5020 and 6020 and they do look great as well but they dont have 4K upscale...
No doubt youll spend some serious hours tweaking the JVC but once you get it set its nothing but a joy to watch.. The only fuss about this projector is it MUST be used in a dark room...ie no window light ....
Thank you for your input. When you say no window light is that no light in the room period or just none from outside? Im just trying to figure out how to configure my dimming system in the room. What is 4k up scaling? This is all new to me. I come from a medical background and have 0 experience in technology. i would still play Oregon trail if it worked on my computer lol.
No meaning any outside or lights on in the room will seriously wash out the image.... Of course no one intends to watch movies et all with the lights on .. but a room full of windows would not be recommended with this projector ie a living room or game room ... its recommended to be in a dedicated Media room with zero outside light coming in.. of course if you have heavy dark curtains or shutters then your good to go...
I wasn't sure if your $5K was just for the projector or does that have to incl the audio equipment as well...
4K is the lastest version of high definition and is commonly referred to as Ultra high definition .. This JVC is not a true 4K image but an enhanced 1080P HD ... All that is to say it looks AMAZING...
See this article for a full review and technical description ....
That is very helpful thanks alot. For 5k I was hoping to have some sort of almost complete cinema room. i know there is always going to be a few unexpected expenses. Im researching the 4k recommendations. I would end up just paying someone to set it up for me. I get to agitated messing with electronics getting them setup properly. The room is perfect for that screen if its meant to be dark, I can keep it blacked out very easily. I know the sound system will prob be an ongoing project as i add more and more speakers unless there is any good ones out that are priced well for the inexpensive whole package. im more interested/confused on the screen/ projector setup. So many options and recommendations makes it almost limitless. Thanks again
If you can try to set the projector away for the seating area is best, some have a fan noise that will overpower the lighter sounds; you don't want to be directly underneath it.
Projectors are great, we really enjoy ours. Can't run them hours & hours every day though, bulbs are expensive and it might only last a few short years.
A lot of people double up with a large LED TV in the theater, maybe under a roll-up screen.
I didnt realize the projector you recommended was about $3500+. If i wanted to spend less is there a good starting point for projectors? Also are there any other 4k ones that are less expensive? My only concern is im new to this so im not sure where to start and dont want to end up with a 8k project by the time im done or a 4k pos.
I guess im just looking for any competitive brands or models so i can see reviews on both and make an educated decision.
I realize i said $5k. i was thinking 5k for screen, projector, and the other goods. Any input is greatly appreciated.
Thank you for input. Can you tell me what brand you have and how much approx you spent? I dont know if i should go all out or be conservative. im lost in all this.
4k seems to be pretty expensive. If i didnt go 4k what is the next best step down? If i did go 4k, how much would a good screen for it run assuming i was somewhere around the 100 to 125in range?
im going to pay to have this setup properlt i just want to make sure i buy the right meat an potatoes.
There are no cheaper 4k projectors.... That said go with 1080P Full HD like the Epson is highly rated............. Im listing some other recommended equipment
It is a bit past budget but I hate recommending cheap equipment that's not going to be at least very descent...The emphasis on these recommendations is the video which will look fantastic....
Wow that is very kind of you to spend the time laying this out like you did. Thanks alot. im looking through the items now and probably going to start ordering them tomorrow. I appreciate you not sending me just to keep budget, that is not my goal. I need QUALITY while staying near that price range. I was looking at this gentleman's due to the budget and setup size being similar to what I was looking to do. Do you mind telling me what your thoughts are of it? I dont care at all for 3d so i just want a overall good projector. Im really excited to have this laid out the way you did thanks a ton.
We've had several projectors, and wife and I are really enjoying ours.
As far as fan noise, can't hear a thing in eco mode.
btw, Best Buys price match with Amazon, so look first there first and print add.
edit: we went cheap on the screen, I think it was only $150 - 105" a silver-ish color.
It's a simple spring roll up, I don't mind it at all, guessing a high dollar one would be better, but okay/fine as is.
A thought about the screen e.g. here the bookcases were in place - just drilled 4" holes in each side. Slipped the screen up-in and it rested on both sides.
Reapplied molding on the outside (original molding concealed). The bottom of screen will slip up into the mini soffit
Highly recommend setting the screen "back" into something, to help keep ambulant light off the screen.
your setup looks very nice. Do you know the dif between the Epson 502UB and the 503UB? It looks like im going to roll with that model if you two guys im speaking with both recommend it. Its hard for me not to take my holiday bonus early and just go all out for the 4k but im sure ill be so excited when this is setup ill forget about it until the price goes down in the next year or so.
I only picked up the 5020 a couple of months ago; $2,500, higher contrast sounds good, but wife and I are very happy. I see there are still some 5020's left, seems they are about $100 less.
Yes three matched speakers up front does work best, not sure you need five to match, but don't use tiny bookshelf speakers in the rear either, you'll want a pretty good size speaker (e.g.7" woofer, 2-way)
Main and rear speakers always sound better away from the wall, if you have the room.
Please drop by some Home Theater places for ideas, they will be glad to show off their systems!!
Personally I like the idea the idea of "separates" and a 5 channel power amp, ours is 95lbs and 1,000 watts, but no bells and whistles and need 3 remotes, which doesn't bother me. This route is more expensive and clunky , but I simply think they sound better.
*Denon, buddy did try one and liked it, I'll check to see which one he had.
One thought about the inexpensive subs; because several friends have asked me to look at the ones that stopped working. I wish manufactures would stop trying so hard with the "auto-turn-on", that seems to be the first thing to break down.
Some have brought in sub/amps that just blew. Also I never had any luck with $99 plate amps; never pushed them hard or connect the less than 4ohm, typ. 8ohm. Out of the 6 I have bought, only 2 are still working.
However not much to lose with a $109 sub (and PE does have a 1 year warranty) if you just want to get up and running; I bet you'll end up with a $1,000+ sub someday.
Keep in mind you will need an AC outlet near the projector...this will require an electrician if you don't all ready have this in place. It will need to be behind or to the side of the pre determined mounting position of the projector ...I only mention that having seen more than 1 electrician put the thing smack in front of the projector without realizing it :duh:
As for a mount my recommendation is this PEERLESS. Ive seen the one that comes free with the EPSON and its extremely cheap and very difficult to adjust properly....The micro gear feature of this PEERLESS makes adjusting very easy in the initial setup....
While the Panny n JVC all look great.. this broke man's budget is around 1000-1500. Can anyone suggest a good projector. Optoma/Epson are brands am looking in my price range. Any suggestions/advices are appreciated.
Related Threads
742.3K posts
170.9K members
Since 2006
