optoma hd180 white specks - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 12 Old 08-01-14, 09:38 PM Thread Starter
mrbashfo
Hi, recently hooked up a optoma hd180 which is very similar to the hd20. However while watching a movie etc... i nptice there are white specks all over the screen and they kind of flash, kind of moves too. Its all over what can be wrong?
Main Home Audio/Video System Equipment List
Electronics- Marantz SR5005, Crown XLS 202D X3, Crown XLS 402D
Speakers - DIY Center, Polk RTI 12s, Polk T15s, MFW-15
mrbashfo is offline
post #2 of 12 Old 08-07-14, 11:30 AM
HTS Moderator
Re: optoma hd180 white specks
Hello!
Do you mean white sparkles? This is caused probably by your screen. Can you tell us more about it? (brand, model, gain etc)
Yiannis1970 is offline
post #3 of 12 Old 08-07-14, 01:02 PM
willis7469's Avatar
Bad hdmi cable.
willis7469 is online now
post #4 of 12 Old 08-07-14, 01:24 PM
tonyvdb's Avatar
Tony
Yup, bad HDMI cable is the most likely cause.
Home theater:
Living room system:
tonyvdb is offline
post #5 of 12 Old 08-13-14, 12:42 AM
RTS100x5's Avatar
RTS100x5
Yes these are the signs of a cheap HDMI cable... I highly recommend the Monster HD 1000 and I use that model to replace "low quality" cables in the field to fix that and other issues all the time... Oh of coarse ALL HDMI CABLES ARE THE SAME.....
RTS100x5 is offline
post #6 of 12 Old 08-13-14, 04:32 PM
HTS Moderator
Reviewer
Mike Edwards's Avatar
sounds very much like a bad HDMI cable. what length of cable are you looking at? if it's under 25 feet just get a nice monoprice cable and be done with it. if you're talking above 25 feet look at their redmere cables
Mike Edwards is offline
post #7 of 12 Old 08-13-14, 04:34 PM
HTS Moderator
Reviewer
RTS100x5 wrote: View Post
no, all HDMI cables are NOT the same, you're correct, but most of the time it's some piece of junk HDMI cable from walmart or bestbuy etc... buying a nice Blue jeans cable, or monoprice cable will be just as good as the Monster for a fraction of the price. plus sometimes it's just a failing HDMI cable, I've seen monster cables that exhibit those issues after years of strain on the connectors.
post #8 of 12 Old 08-13-14, 04:46 PM
HTS Senior Moderator
nova's Avatar
Mark
Really? Interesting, I've never heard that before about the white dots. I had always assumed that since it was digital it either worked or it didn't. That has also been my experience with bad HDMI cables, they just didn't work.
Is there an explanation as to how the bad cable causes white dots?
Mark
nova is offline
post #9 of 12 Old 08-13-14, 04:49 PM
HTS Moderator
Reviewer
nova wrote: View Post
nah, sparkling is the least common of the two, but it does happen. usually it's because it's bitstarved and the cable isn't handling the throughput like it should be, but with the invention of high speed HDMI cables that's usually a thing of the past. BUUUUUUUUUUT there are some el cheapo cables out there that don't pass it very well. I recently had a ground loop hum happen from a cable that came in the box with my sony 590 bd player. swapped it out for a 26 awg hdmi 3 footer from monoprice and voila.
post #10 of 12 Old 08-14-14, 03:37 PM
Plain ole user
lcaillo's Avatar
Tech Guru
If it looks like random noise or streaks, the HDMI cable is possible. If it is always the same points on the image it is a bad DMD, which is not uncommon on DLP.
lcaillo is offline
hd180 , optoma , specks , white
