Sanyo PLV-Z4 Reviews | Owners and Service Manual - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 23 Old 12-11-06, 10:56 PM Thread Starter
Re: Sanyo PLV-Z4 Reviews | Owners and Service Manual
You can right click the file and "Save As" and save it to your computer, then open it in Adobe Acrobat Reader... should be no problem. The issue is opening it from this site. There are some modifications that I'll have to check into in order to get them to open from the site.
Sonnie is offline
post #12 of 23 Old 12-12-06, 03:55 AM
billando
Inactive
Posts: n/a
Sonnie wrote: View Post
Cant get the right click save as to work either Sonny.
Tossing up whether to buy Z4 or Z5 seen the Z4 today and it is definately good enough for me. Can't imagine the Z5 could be that much better but maybe some can enlighten me.
Cheers Bill
post #13 of 23 Old 12-12-06, 07:36 AM Thread Starter
Hmmm... I don't know what's going on with the file. I've looked at everything I know to look at. It works for someone else I had test it. Our server isn't doing anything to it.
As far as the differences between the Z4 and Z5, Projector Central has a pretty nice review of the Z5.
Sonnie is offline
post #14 of 23 Old 12-12-06, 09:37 AM
thiyagy
Thanks a lot Sonnie, I could save the service Manual as U had indicated by right clicking...
Thanks once again.
thiyagy is offline
post #15 of 23 Old 12-14-06, 11:23 AM Thread Starter
We think we found the culprit and those files should open with no problems now.
Sonnie is offline
post #16 of 23 Old 12-14-06, 02:55 PM
billando
Inactive
Posts: n/a
Hi Sonnie,
The links work fine now. Thanks for that.
Cheers Bill
post #17 of 23 Old 12-30-06, 12:09 PM
Mookie
Inactive
Posts: n/a
If your bulb is not coming on and the lens protector slides closed 10 seconds after you turn it on, it may be the same problem I've had a couple of times with a brand new PLV-Z4. I called the support line and they talked me through a simple fix. I had to reset the thermostat. FIRST, unplug the power cable. Then you gotta open up the case. Take out the screws on the bottom. Then put the baby down right side up (legs on floor) and pull the shell up but NOT OFF because there are wires connecting the shell to the body. Don't touch anything else, only this: in the corner, you'll see a round black plastic gizmo with a white tip in the center. Tell everybody in the room to shut up because you need a quiet room to hear this. Press down on the white center tip until your hear it click once. That's it. Now put the shell back on and put the screws back in. I don't know why the thermostat does this but I can tell you that it has now done it three times and I've had the projector less than two months. The projector does not get hot and the fan stays on to cool off after the unit is turned off. So now, I don't put the screws back in to make it easier to go in and reset the button. Other than this pain in the neck fault, I love the projector. Good luck and don't electrocute yourself!
post #18 of 23 Old 01-02-07, 06:04 AM
billando
Inactive
Posts: n/a
Hi Guys,
Bought home new Z4 today. Just been playing DTS demo dvds on denon 2910 player. I think I will be smiling in my sleep tonight. hehehe. Thanks again sonnie for making service manual available could be very helpful in years to come.
Cheers Bill
post #19 of 23 Old 01-02-07, 08:11 AM Thread Starter
Congratulations Bill... I'm sure you will enjoy it for years to come...
Sonnie is offline
post #20 of 23 Old 09-30-07, 10:00 AM
tbase1's Avatar
tmack
whats the best calibration setting for the Z4 using HDMI from hd-dvd and blu-ray?
tbase1 is offline
manual , owners , plvz4 , reviews , sanyo , service
