confused about 2:35:1 screen - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 22 Old 03-07-08, 07:20 PM Thread Starter
Does a person have to have a anamorphic lens to use a 2.35 size screen?And what are the benefits of this shape?
record_breaker is offline
post #2 of 22 Old 03-07-08, 07:23 PM
muzz
Re: confused about 2:35:1 screen
Hey RB,
Your better off asking this particualr question in the anamorphic section.....
Here is the link:
http://www.hometheatershack.com/foru...ic-projection/
muzz is offline
post #3 of 22 Old 03-07-08, 07:57 PM
Mike P.'s Avatar
Mike
Thread moved to Anamorphic Projection.
We're all in this together!
Mike P. is offline
post #4 of 22 Old 03-08-08, 05:58 PM
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
record_breaker wrote: View Post
You can fill a 2.35:1 screen by just zooming the lens on the projector...But you will have to change the zoom and the focus and the positioning for all the other aspect ratio's..
One of the advantages of the anamorphic lens with a constant image height screen is that you don't have to change any of these settings for most AR's..
The 2.35:1 image fills the screen, and the other AR's remain at the same height, with black bars at the sides..
But the main advantage is that you are getting full pixel mapping with the 2.35:1 image, unlike the zooming method..
I hope that helps to clear things up for you..
Prof..
Home Theatre...the never ending story!
Prof. is offline
post #5 of 22 Old 03-08-08, 06:51 PM Thread Starter
Prof. wrote: View Post
OK see if I understand this I can build a screen specifically for athe 2:35:1 image and use my Zoom to fill up the screen vertically but I'll lose a little picture on the width?
post #6 of 22 Old 03-08-08, 09:18 PM
Mark Techer
When you zoom onto a Scope screen, your width will remain full, but you will lose 25% (approx) of the vertical rez due to the black bars that you are now projecting off the top and bottom. Another thing to consider is that as you zoom, your pixels become larger in both H and V directions, where using an anamorphic lens only expands the pixels horizintally...
The anamorphic Lens allows you to use 100% of the panel, so full vertical rez all the time...
Mark
Mark Techer is offline
post #7 of 22 Old 03-09-08, 03:28 AM
Maverick
But you need a dedicated video processor to allow this?
Status: Sold!
Status: Done
Status: Sold!
Status: Sold!
atledreier is offline
post #8 of 22 Old 03-09-08, 04:22 AM
Mark Techer
atledreier wrote: View Post
No. Many projectors manufactures are now allowing the needed scaling to be done from simple Plug and Play systems. Some of these are SONY, BenQ and JVC...
Mark
post #9 of 22 Old 03-09-08, 06:37 PM
Prof.'s Avatar
The Mad Professor
Mark Techer wrote: View Post
Mark
And Optoma...my next choice!
Prof..
Prof. is offline
post #10 of 22 Old 03-09-08, 07:57 PM
Mark Techer
And I am tossing between the SONY VW60 or the BenqW5000.
So long as it can do 1080/24 and scale for CIH, nothing else really matters...
Mark
confused , screen
