-   Home Theater Projectors (https://www.hometheatershack.com/forums/home-theater-projectors/)
-   -   Benq W1070 brightness at shorter distances? (https://www.hometheatershack.com/forums/home-theater-projectors/130098-benq-w1070-brightness-shorter-distances.html)
hypermonkey2 08-25-15 01:51 PM
Hi all,
I'm planning a home theatre, and am limited to viewing distance of about 10 ft, and i can have a throw distance up to 12ft about.
I was interested in the Benq W1070, but calculators tell me that to have a recommended viewing distance of a minimum of 10ft, throw distance is 10'9''. this will give 98'' diagonal image (which may be too big, but could potentially work)
So essentially that works, but if i need to go for a smaller screen (80'' for example), i would need to bring the projector closer to the screen, but then i run into image brightness issues right? I would need for ambient light?
Just looking for some advice, or maybe none of this is really important and it'll look just fine :)
tl-dr: Does anyone else worry about image brightness (too bright?) for shorter throws/viewing distances (10-12ft)?
Yiannis1970 08-28-15 01:19 PM
Re: Benq W1070 brightness at shorter distances?
If your seating distance is ~10ft, i would go to 98'' with no problem if i were you. Do not forget that many many films opt for 2,35:1 format. It means that you will lose 6'' more going at 92''.
jwhiteman 03-13-16 03:02 PM
Yiannis1970 wrote: (Post 1283082)
I agree
