-   Home Theater Projectors (https://www.hometheatershack.com/forums/home-theater-projectors/)
-   -   optoma hd180 white specks (https://www.hometheatershack.com/forums/home-theater-projectors/88281-optoma-hd180-white-specks.html)
mrbashfo 08-01-14 09:38 PM
Hi, recently hooked up a optoma hd180 which is very similar to the hd20. However while watching a movie etc... i nptice there are white specks all over the screen and they kind of flash, kind of moves too. Its all over what can be wrong?
Yiannis1970 08-07-14 11:30 AM
Re: optoma hd180 white specks
Hello!
Do you mean white sparkles? This is caused probably by your screen. Can you tell us more about it? (brand, model, gain etc)
willis7469 08-07-14 01:02 PM
58 Attachment(s)
Bad hdmi cable.
tonyvdb 08-07-14 01:24 PM
Yup, bad HDMI cable is the most likely cause.
RTS100x5 08-13-14 12:42 AM
Yes these are the signs of a cheap HDMI cable... I highly recommend the Monster HD 1000 and I use that model to replace "low quality" cables in the field to fix that and other issues all the time... Oh of coarse ALL HDMI CABLES ARE THE SAME.....:whistling:
Mike Edwards 08-13-14 04:32 PM
sounds very much like a bad HDMI cable. what length of cable are you looking at? if it's under 25 feet just get a nice monoprice cable and be done with it. if you're talking above 25 feet look at their redmere cables
Mike Edwards 08-13-14 04:34 PM
RTS100x5 wrote: (Post 875505)
no, all HDMI cables are NOT the same, you're correct, but most of the time it's some piece of junk HDMI cable from walmart or bestbuy etc... buying a nice Blue jeans cable, or monoprice cable will be just as good as the Monster for a fraction of the price. plus sometimes it's just a failing HDMI cable, I've seen monster cables that exhibit those issues after years of strain on the connectors.
nova 08-13-14 04:46 PM
Really? Interesting, I've never heard that before about the white dots. I had always assumed that since it was digital it either worked or it didn't. That has also been my experience with bad HDMI cables, they just didn't work.
Is there an explanation as to how the bad cable causes white dots?
Mike Edwards 08-13-14 04:49 PM
nova wrote: (Post 876489)
nah, sparkling is the least common of the two, but it does happen. usually it's because it's bitstarved and the cable isn't handling the throughput like it should be, but with the invention of high speed HDMI cables that's usually a thing of the past. BUUUUUUUUUUT there are some el cheapo cables out there that don't pass it very well. I recently had a ground loop hum happen from a cable that came in the box with my sony 590 bd player. swapped it out for a 26 awg hdmi 3 footer from monoprice and voila.
lcaillo 08-14-14 03:37 PM
If it looks like random noise or streaks, the HDMI cable is possible. If it is always the same points on the image it is a bad DMD, which is not uncommon on DLP.
