Ultimate Behringer iNuke 1000/3000 Fan Mod - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 02-01-15, 08:50 PM Thread Starter
The Ultimate Behringer iNuke NU3000DSP Fan Mod (CLICK HERE FOR PICTURES):
After purchasing an iNuke, I found the stock fan far too loud for home theater use. I liked seeing what people were experimenting with here (slower fans, inline resistors to slow down the stock fan, natural convection), but I didn't like the compromise that in almost all cases the capabilities of the fan were reduced or eliminated. Aside from the lowered cooling ability, I was concerned that any fan bearing, no matter how silent, would not address the issue of the noise form the air rushing out of the louvers in the front bezel. This mod not only reduces the fan noise to imperceptible levels, but also substantially increases the heatsink area and CFM of air flow.
I chose a fluid dynamic ball bearing because it is the quietest and longest lasting type of case bearing available. I went with the Cougar 140mm fan because it has a true Matsushita designed fluid dynamic bearing. Here is an excellent write up and a list of fans with the best fluid dynamic bearings: fan bearings. Another benefit of the Cougar, aside from its impressive build quality, is the inclusion of an inline resistor that will drop the fan from a maximum of 1200rpm (19.2dB) to 700rpm (16.4dB). I did not use the resistor since the system is absolutely imperceptible at a couple meters, but even with the resistor installed, this fan will still push as much air as the stock fan. Without the resistor, this fan flows 70.5CFM (19.2dB) compared to the stock fans 55.5CFM (40.9dB). Make sure to get the 3-pin design and not the 4-pin PWM fan. This fan has some awesome rubberized insulation that I didn't want to screw up, so I just used a cheap 3-pin to 2-pin adapter listed below. The one down side of the Cougar is it doesn't include a fan grill. I picked up a 2-pack from newegg.com for $5. I'm not into a flashy home theater, so I went with the black fan, but it is also available in a bright orange blade fan that will match the iNuke.
As for the heatsinks, I used black anodized aluminum 28x28x13mm IC heatsinks. I would have used straight fin heatsinks below the fan for improved cooling performance, but I ultimately chose the cross cut style because I could not predict how air would flow across the heatsinks on the power supply side and I didn't want to buy two different types. I first cleaned all of the tabs with a little alcohol to remove any oils. By bending the output stage MOSFET heat tabs up to about a 60 degree angle a heatsink can be mounted on the top and bottom. I left the power supply heat tabs flat and placed a single heatsink on top of each. Make sure none of the adjacent heatsinks are able to touch each other, and also make sure the power supply heatsink fins are inline so they don't block flow from each other or cause unnecessary turbulence.
I masked off the lid and took measurements of the internal components to be able to layout the cutout for the fan. Make sure to measure repeatedly and keep track of the front, back, left, and right. After determining a center point, I took a nail a punched in an impression to guide the pilot bit of the hole saw. I fortunately already owned a 5 1/4" hole saw, but if you don't, then you will have to figure in an additional $35 for a hole saw from amazon.com. Once the hole was cut out, I used a pocket square and the fan grill as a guide to punch and drill the fan mount holes with a 13/64" drill bit. I then cleaned up the cut aluminum with a rat-tail and flat basterd file (I had to misspell this since this site doesn't like the proper name of a tool).
I installed the fan utilizing the included rubber mounting tabs and then snipped off the ends. I didn't want to have a gaping hole in the back (lol), so I purchased a few 8-32 machine screws and reinstalled the stock fan grill. I was considering cutting a piece of the stock fan shroud and limiting the amount of air that could flow directly out of the back, but after running it, I believe there is plenty of cold air flowing out of the front of the amp even with the back completely open. In the end I have an amp that is effectively silent, yet is cooled far better than the stock Behringer design. I am very pleased with it, and I do not baby it in anyway. The obvious limitation is that nothing can be set on top of the top-mounted fan, and if it is rack-mounted, it will have to have an open slot above it. My total cost was $42.04. If you have to buy the hole saw and a role of masking tape, figure the price at about $80. This puts a silent "3000w" home theater amp with on board DSP at about $360.
The Stock Fan
For anyone wondering, the fan in a recently shipped iNuke300DSP is a "Bi-Sonic BP802512HL-03-W". It is a 12V 80x80x25mm 2-pin fan with a maximum of 55.53CFM at 4000rpm and a stated 40.9dB-A
Here is the datasheet: http://datasheet.octopart.com/BP8025...eet-525890.pdf
These are a couple interesting links I found when looking for the best heatsink design:
Why you should consider straight fin heatsinks, if possible, when you know the direction of airflow:
https://www.aavid.com/sites/default/...n-heatsink.pdf
Why you should choose anodized heatsinks for natural convection systems:
http://www.aavid.com/product-group/e...ons-na/anodize
PARTS:
COUGAR CF-V14HB Vortex Hydro-Dynamic-Bearing (Fluid) 300,000 Hours 14CM Silent Cooling Fan (Black) - $17.99
http://www.newegg.com/Product/Produc...82E16835553007
APEVIA G-140MM 140mm Fan Grill 2 in 1 pack - $4.99
http://www.newegg.com/Product/Produc...-078-_-Product
FREE Shipping 10pcs 28x28x15mm Cheap CPU Black Aluminum Heatsink With Blue Thermal Conductive Double Sided Adhesive Tapes - $15.00
http://www.aliexpress.com/snapshot/6...65459518779892
30cm Fan Adapter Cable Case Ventilation 3-Pin Plug 2-Pin Jacket Coupling - $2.50
http://www.ebay.com/itm/30cm-Fan-Ada.../331312882600?
4x 8-32 Machine Screws with Washers and Nuts - $1.56
funkingitup is offline
post #2 of 8 Old 02-04-15, 01:54 PM
Blueleader's Avatar
Beat Down and Broken
Re: Ultimate Behringer iNuke 1000/3000 Fan Mod
Not to highjack but anybody have experience with the following Nu1000DSP amp failure. I was changing my setup from bridged to dual and everything tested good but after 30 minutes of the amp being off I turned it back on, the fan went full revs and in about 5 seconds I heard a loud pop and the amp failed. If I turn it on now the lights up front are red and the amp fails to drive the subs. I have tested and inspected the speakon connections and they are correct. A warranty repair is going to be an expensive shipping pain in the butt. Also, I am running two 18inch SI subs at 4 ohms each, one per channel so ohms are within tolerance.
Blueleader is offline
post #3 of 8 Old 05-08-15, 12:53 PM Thread Starter
The top mount 140mm fan is running great. I addressed the light issue from the amp by buying a $2 Sealing Washer Assortment from Harbor Freight. I placed two of the 15x24x3mm washers included around the knobs. In both cases the light is much dimmer to the eye than what the picture shows.
BEFORE:
AFTER:
post #4 of 8 Old 07-05-15, 08:24 PM
Funkingitup, how is the fan mod working so far? Also, do you think i could get away with just the fan and no heat sinks?
Bloodta is offline
post #5 of 8 Old 03-18-16, 04:57 PM Thread Starter
Bloodta wrote: View Post
Wow, sorry man! I missed this a long time ago, but if you are still around, the fan is excellent. It is blowing cool air silently over the massive heatsinks. I blast it with movies and music, and it doesn't miss a beat. The one area I would have done differently was gluing the power cable to the fan down to the board. When I moved, the fan connector fit loosely and came undone. Luckily I noticed this was the case, so I plugged it back in and put a drop of glue. I still haven't seen a better mod for this amp, and unless someone wants to prove me otherwise, this is the cheapest watt per dollar of any silent hometheater amplifier with DSP. Do it!
post #6 of 8 Old 03-18-16, 07:06 PM
funkingitup wrote: View Post
No problem, I did it a while back. I also glued the power cable down, it works great.
Bloodta is offline
post #7 of 8 Old 03-19-16, 04:53 AM
morca's Avatar
morca
This is my mod works fine.
Simulation is no substitute for thought.
morca is offline
post #8 of 8 Old 05-31-17, 01:11 PM
New Member
synessence
I'm keen to implement this project on my own iNuke but the images don't appear to be serving any longer at the link provided. Any chance you might provide them again?
synessence is offline
behringer , fan , inuke , mod , ultimate
