X4000 crossovers do not work? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 31 Old 03-03-15, 05:04 PM
rab-byte's Avatar
Mr. Rabbit
LPF is set to 120hz
LFE is set to 80hz
You're hearing LPF crossover to the sub.
rab-byte is offline
post #12 of 31 Old 03-03-15, 05:39 PM Thread Starter
Talley's Avatar
Re: X4000 crossovers do not work?
rab-byte wrote: View Post
LPF is set to 120hz
LFE is set to 80hz
Well, I changed both the speaker crossovers to 40 and the LFE to 40 and nothing made any difference yet when I flipped the switch on the HSU and manually cut it down to 40 it did it immediately.
Master Electrician
XPA-7 & Krell Showcase 7 | XMC-1 | SVS Ultra Tower system | HSU VTF-15H MK2 | BenQ W1070 | Jamestown 135"
Talley is offline
post #13 of 31 Old 03-03-15, 08:23 PM Thread Starter
Talley's Avatar
Update:
Hard reset corrected the issue. After setting everything back up and running Audyssey again and then going into the speaker config for manual setup I was changing the crossover and immediately would have a cutout and it would work.
...however the thing powered off three times... like just shut down during a movie for apparent reason and I had to turn the AVR back on. Very weird. Each time a message came back up about updating the firmware which I just did a few weeks ago. I'lll update it and keep an eye on it.
But yes, thank you all for the help. A reset got the crossovers to work again.
Master Electrician
Talley is offline
post #14 of 31 Old 03-03-15, 09:05 PM
tonyvdb's Avatar
Tony
A shutdown is not good, make sure all your speaker connections are clean and no bare strands are touching anything but the binding post on all speakers and receiver.
Does it shut down during loud passages?
Home theater:
Living room system:
tonyvdb is offline
post #15 of 31 Old 03-03-15, 09:14 PM Thread Starter
Talley's Avatar
Everything is good on the connections. Did it three times but I remember it doing this once about a week after I bought it. I suppose that is what I get for buying a refurb. It may be the HDMI cord to the projector. I noticed the connector was a tad loose on it like it got jarred. It was a cheapy from amazon. Might just order a redmere see how that works out.
Master Electrician
Talley is offline
post #16 of 31 Old 03-03-15, 09:15 PM Thread Starter
Talley's Avatar
now my audyssey results are kinda funky to say the least. weird stuff and the bass is just no where to be found.... definately had to do a +6db on the sub level
Master Electrician
Talley is offline
post #17 of 31 Old 03-04-15, 08:56 AM
tonyvdb's Avatar
Tony
Where do you have the level on the sub its self?
Home theater:
Living room system:
tonyvdb is offline
post #18 of 31 Old 03-04-15, 09:00 AM Thread Starter
Talley's Avatar
tonyvdb wrote: View Post
Um... a tad lower than what HSU recommends I think they say 9 oclock position and mines a bump hair under that probably at the 8:30 mark. The level knob on their subs are very sensitive. Either way Audyssey wants it leveled to 75db for their tests to begin.
I'll post up some before/after graphs.
Master Electrician
Talley is offline
post #19 of 31 Old 03-04-15, 09:09 AM Thread Starter
Talley's Avatar
Here are some REW graphs... seems like the midbass took a hit.
I DO REMEMBER.... Before my sub was sideways with the port facing the right wall. All I did after was turn the sub so the sub faces into the room....
This could be the cause maybe but my speakers did not move. I need to play around with the speaker locations I supppose.
Master Electrician
Talley is offline
post #20 of 31 Old 03-04-15, 09:17 AM
tonyvdb's Avatar
Tony
9 O'clock is low, its generally recommended to start off at 12 o'clock on the subs level control.
Home theater:
Living room system:
tonyvdb is offline
crossovers , work , x4000
