X4000 crossovers do not work? - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 31 Old 03-04-15, 09:22 AM
Charlie
Depending on what's actually on the media's LFE track you might get 100-250 out of the subwoofer so that may or may not have been an issue.
Keep using the same media for all testing so that part of the system is stable and repeatable.
If you are using an amp is it driving all speakers or is the AVR handling part of the load?
chashint is offline
post #22 of 31 Old 03-04-15, 09:23 AM
Charlie
What is the audessey setting the sub trim at?
chashint is offline
post #23 of 31 Old 03-04-15, 09:26 AM Thread Starter
Talley's Avatar
Re: X4000 crossovers do not work?
tonyvdb wrote: View Post
9 O'clock is low, its generally recommended to start off at 12 o'clock on the subs level control.
chashint wrote: View Post
My sub is set to to around the 8:30 and HSU recommends 9 oclock. After audyssey runs it's tests typically it's in the -3db to -5.5db. last nights test it landed it on the -3db mark.
Master Electrician
XPA-7 & Krell Showcase 7 | XMC-1 | SVS Ultra Tower system | HSU VTF-15H MK2 | BenQ W1070 | Jamestown 135"
Talley is offline
post #24 of 31 Old 03-04-15, 09:27 AM Thread Starter
Talley's Avatar
I re-watched FURY the 4 tank vs. 1 tank scene and although it lacks subsonic bass it has very good bass in the 35-100hz range and the movie did not sound the same as before.
I'll have to play around with it and turn the sub back like it was and re run audyssey again.
Master Electrician
Talley is offline
post #25 of 31 Old 03-04-15, 09:29 AM
New Member
i dont think so?
jamessalva is offline
post #26 of 31 Old 03-04-15, 01:42 PM
Charlie
Since audessey is setting the subwoofer channel to -3dB the volume control on the sub is set correctly.
chashint is offline
post #27 of 31 Old 03-04-15, 01:47 PM Thread Starter
Talley's Avatar
Exactly. It's dialed in good. However I can run tests several times back to back and it's anywhere from -5.5db to -3db. Which is fine and I usually bump it about 2-3db for my liking.
I think the issue before was the crossovers being messed up I was getting overlap from the speakers to sub.
I need to start playing around with placement now is all.
Master Electrician
Talley is offline
post #28 of 31 Old 03-04-15, 04:08 PM
Charlie
Another way to look at -5.5 to -3.0 is +/- 1.25dB which is actually pretty good.
chashint is offline
post #29 of 31 Old 03-04-15, 10:03 PM Thread Starter
Talley's Avatar
eh... The X4000 is constantly shutting down. I've checked everything... unplugged all the HDMI... and did it back to back to back to back at one point... shuts down then blinks orange about once a second.
Let it sit off for awhile and then no issues. I remember now what was happening before when it did it. It was day 29 of purchase before it happened so I was basically past the A4L return... but back then only did it once and didn't think much of it.
The hard reset brought it back ugh. Remember I have no speakers connected to the X4000 I'm using RCA connections to the Krell.
Looks like I either:
A. send it to Denon
B. Buy another X4000 and wait for other one get repaired then sell it off
C. Buy marantz model... I think Sonnie has one available for 1500.
Either way I don't tolerate bad equipment. Bummer.
Master Electrician
Talley is offline
post #30 of 31 Old 03-05-15, 06:26 AM
Charlie
I don't know if A4L can do anything for you or not, but a phone call and asking nicely never hurts and the price is right.
chashint is offline
crossovers , work , x4000
