Looking for receiver recommendation - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 16 Old 07-10-15, 07:10 AM Thread Starter
I am putting together a new surround sound setup based on DIY speakers. The speakers I am building are 3 x Creative Sound V2 (L/C/R) and V1 (surround). I may also add rear surround in future. I've been out of the surround sound world for quite some time.
  • Here is what I am looking for in a receiver:
  • I am in an apartment and do not listen at loud volume so 30 WPC+ clean should be plenty of power
  • Do not need atmos
  • Would consider buying used, cost is a consideration would like to stay under $600 CAD. Even lower would be great.
  • 4-ohm and 6-ohm compatible
  • Pre-outs would be nice (even if for stereo only)
  • 4K not required
  • Mostly to be used for Music, Blu-ray, streaming (Netflix) and occasional gaming.
Thank you for any help!
Wiggle is offline
post #2 of 16 Old 07-10-15, 08:32 AM
tcarcio's Avatar
TC
Re: Looking for receiver recommendation
You can check out www.accessories4less.com for some really good deals. I have bought 2 receivers from them and have always been satisfied. Their customer service is great also which is a big deal IMO. Here is just one that would fit your requirements but look around the site for allot of great deals. http://www.accessories4less.com/make...arranty/1.html
Onkyo TX-NR809 HT receiver
HPS-4000,SR-70, John Allen, Klipsch Heresy, Speakers for L.C.R.
QSC GX-5 power amp for L+R mains
Chase Home Theater PRO-10's for surrounds
Behringer EP 4000 pro amp for the Danley DTS-10 tapped horn sub
Oppo BDP-93 universal BD player
Toshiba HD XA2 HD dvd player
Sony VW-VPLPRO1 1080p PJ
Cinema White 1.0 gain 106" fixed frame screen
Dish network with 2 Hoppers and 1 Joey
tcarcio is offline
post #3 of 16 Old 07-10-15, 08:46 AM Thread Starter
Thanks, that site looks really good. I'm actually kind of looking at the Marantz 5008 on there now: http://www.accessories4less.com/make...specifications
Wiggle is offline
post #4 of 16 Old 07-10-15, 10:41 AM
tcarcio's Avatar
TC
That is a great choice also. Marantz are also good to go with 4 ohm speakers so no problem there. And with the pre-outs you can add an external amp if you decide to.
tcarcio is offline
post #5 of 16 Old 07-10-15, 10:52 AM Thread Starter
Thanks, the NR1605 has also caught my eye. I like the profile and the power should be sufficient. It also has front pre-outs which is all I'd really ever want to use. Would that be a reasonable choice as well?
I assume these prices are in USD? Just trying to figure out my cost to get it to Canada.
Wiggle is offline
post #6 of 16 Old 07-10-15, 11:05 AM
tcarcio's Avatar
TC
The thing about the 1605 is it has the lower version of Audyssey room correction so that would make a difference, to me anyway, But that would be your choice. If you can find a receiver with the better version of Audyssey like XT that would give you better room correction which is also something to consider. If you have space issues than the 1605 might be a better fit for you.
tcarcio is offline
post #7 of 16 Old 07-10-15, 11:09 AM
tcarcio's Avatar
TC
I didn't know you were in Canada. I would think you might be looking at another $100-$150 so that would have to be factored in your budget.
tcarcio is offline
post #8 of 16 Old 07-12-15, 01:06 PM
Kyle
Get the best Onkyo , or Denon . Which brand do you prefer OP?
kingnoob is offline
post #9 of 16 Old 07-12-15, 01:08 PM
Kyle
tcarcio wrote: View Post
Do speakers on this site have defects? Why are they marked so cheap??
kingnoob is offline
post #10 of 16 Old 07-15-15, 07:57 AM
Chromejob's Avatar
David S.
kingnoob wrote: View Post
Closeouts and liquidation, most likely. Open box, refurbished, etc.
“Say, was you ever bit by a dead bee?”
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550.
Chromejob is offline
receiver , recommendation
