Gain Structure for Home Theater Discussion Thread - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 85 Old 03-11-13, 07:36 AM Thread Starter
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Gain Structure for Home Theater: Getting the Most from Pro Audio Equipment in Your System
Hey Alain,
Typically the amp would only need to have its gains run wide open if it was getting a weak input signal. However, from what I’ve picked up on various forums, Onkyo receivers have unusually high voltage levels from their RCA outputs. So starting with the amp’s gains maxed out is a bad idea in your case. Your best bet would be to ignore what “everyone” is telling you and follow the simple steps laid out in Part 9 of the article.
post #32 of 85 Old 03-11-13, 08:03 AM
apilon's Avatar
Alain Pilon
Hey Alain,
Thanks Wayne
I believe i will need to perform step 7 before to get the sub maximum usable clean output ?? If so do i need to measure the mains also as stated or can i just measure the sub output?
Finally just to make sure i understand correctly, step 3 adjust the level of all channels utilizing outboard amplifiers to their max settings . Are you refering to the AVR trim level that i should max out to +15DB ??
apilon is offline
post #33 of 85 Old 03-11-13, 10:05 AM Thread Starter
Part 7 is mainly to help people determine if their receiver generates enough clean voltage to drive a pro amp. We already know that yours can, so you can skip that part. Just set your AVR’s sub output for 0 dB and adjusted the amp’s gains as needed, per Part 9.
post #34 of 85 Old 03-11-13, 02:20 PM
Hi Wayne
I look forward to reading the rest of this article but I started on #5 (Myths) and am having a problem with a couple of your statements.
RE: "A 24-bit system in particular can shed several hundred thousand LSBs from its 16,777,216 quantization steps"
While it may be true that a 24-bit system could "shed several hundred thousand STEPs from its 16,777,216 quantization steps" it cannot shed more BITs than it has. Hence a 24 bit system will have One (1) MSB and 23 bits that are less significant and could possibly be called LSBs though once you get past halfway (12 bits) it starts to become semantics.
Any way you slice it you can not shed more bits than exist. ie 24
RE: The chart you show with the three bit system.
You have a left axis labelled "000 001 010 011 100 101 110 111" and you illustrate the loss of a BIT as being synonymous with the loss of the "000" state. This is incorrect
Loss of a bit isn't "really loss of the bit it is loss of the "usefulness" of the bit and the LSB is also NOT the lowest state representable by the system as you have shown.
A more correct chart would have had its left axis labelled "00x 00x 01x 01x 10x 10x 11x 11x". Note that ALL of the LSBs on the axis have been changed to 'x' representing the fact that while they still exist they cannot be relied on to provide [good] data.
In addition the sharp red line showing the steps should be changed to reflect this "uncertainty" by becoming a pinkish-grey area encompassing that part of the graph where the LSB could be either a '1' or a '0' .
Following the top edge of this grey area would show that now you actually have a TWO (2) bit system with another bit worth of grey area below it. The "uncertain area", where "valid data" does not exist is commonly referred to as noise.
An interesting extension of this chart would be to "lose" two (2) LSBs.
With the chart as you depict it only "two states" would be lost but with the axis label correctly it would depict a one (1) bit system with a considerable pink-grey area.
Of course the logical conclusion to this would be a 3-bit system with the loss of ... ... wait for it ... the three (3) LSBs the label would be an uninteresting list of 'xxx' and the entire chart would be pink-grey and it would be easy to see that the chart is nothing but noise.
dsime42 is offline
post #35 of 85 Old 03-11-13, 06:21 PM
apilon's Avatar
Alain Pilon
Got it Thanks
2 more questions and i am on my way......
1. Do i leave the clip limiter on or off for that test on the ep4000?
2. as for the avr volume to i set it to max or 0db reference level?
apilon is offline
post #36 of 85 Old 03-11-13, 07:37 PM Thread Starter
dsime42 wrote: View Post
Hi Wayne
Thanks for clarifying, desime. The 3-bit graph came from Wikipedia (http://en.wikipedia.org/wiki/A/D_converter). Not being well versed in the finer points of A/D conversion, when they showed a quantization step as a LSB(it) I presumed that “bit” and “step” were the same thing.
The point of the discussion was to show that despite the fables that have circulated the home audio forums for nearly 15 years, 24-bit processors are essentially immune to poor input signal levels – you didn’t shoot that part down, so hopefully I’m okay there!
post #37 of 85 Old 03-11-13, 07:40 PM Thread Starter
apilon wrote: View Post
I’d leave it off for the gain setting process. The whole purpose of the gain structure exercise is to make sure the amp clips at the same time as the pre-amp. So, once that’s done, the limiters merely add an extra layer of protection.
That said, I think most people would agree that 30 Hz is way too high a high pass filter for a home theater subwoofer. That essentially reduces the extension of a beefy DIY sub to par with the typical 10-inch manufactured sub.
With your receiver, which has perhaps 2-3 times the output of most others, I don’t think you have to be overly concerned by all this. You can just adjust the amp’s gains for subwoofer level setting the same way that you would for a common powered sub.
post #38 of 85 Old 03-13-13, 11:38 PM
apilon's Avatar
Alain Pilon
Good evening Wayne
I performed the steps in part 7 sub trim 0db played the sin wave but bottom line i had to max out the Onkyo volume to +18db in order to get the Behringer ep4000 to clip and got a steady clip light at +25db on the ep
Thanks for your help
Alain
apilon is offline
post #39 of 85 Old 03-20-14, 08:00 AM
New Member
hdtv4me
Wayne, thanks for this great thread on gain setting. I guess I'm a little late to the party.
I have a Denon 4520 that I'm trying to match up with a Crown XLS2500. Running through your steps I am a bit stuck determining the 4520 preout harmonic distortion threshold. I downloaded your test tones to a USB stick and are running the tones off the USB stick and 4520's MP3 decoder. Using the 1kHz sine signal I can easily detect harmonic distortion once I hit 78 on the Denon volume control (whereby the range is set for 0-98). The problem I have is that I hear this distortion at 78 no matter how high or low the speaker levels are set for - on the 4520, that would be -12 to +12dB. Is this typical? Wouldn't I expect to at least "move" the harmonic distortion point along the volume continuum as I change the speaker levels? Any reason why I can only hear it at volume level 78?
tomstrade is offline
post #40 of 85 Old 03-30-14, 04:32 PM Thread Starter
Hey Tom,
So you’re saying that you run the Denon’s master volume up to 78, and at that point you can hear the distortion begin. And from there if you adjust the per-channel level from the menu for the speaker you’re hearing, that there is no change? IOW, you can reduce the volume of the speaker that way and still hear distortion?
If that’s the case, yes I would think that’s unusual, but then again there are just too many receivers on the market for me to know if this is typical or not, and digital processing can be tricky.
discussion , gain , home , structure , theater , thread
