Gain Structure for Home Theater Discussion Thread - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
post #61 of 85 Old 07-17-15, 02:36 AM
Re: Gain Structure for Home Theater: Getting the Most from Pro Audio Equipment in Your System
Thanks for the reply.
When I measure my AVP subwoofer channel maximum output voltage:
set Left and Right channel to small, set crossover at the highest possible frequency
set the AVP to Stereo mode
adjust the master level of AVP and the level for sub channel to max setting
Play 60 Hz Sine Wave 0 dBFS by Blu-Ray player(oppo 103d)->
send PCM to AVP(EMOTIVA UMC-200)->
measure the sub output voltage
But when I play a blu-ray movie with DTS-HD/Dolby TrueHD, the LFE channel is pre-set to play LFE data 10 dB higher than a main channel (or 10dB higher than the bass from a main channel). I believe this is the reason that channel 4 output of REW is 10dB higher than other channels.
So my question is that, for the maximum subwoofer output voltage when watching movie with DTS-HD/Dolby TrueHD encoded, do we need to add 10db with the subwoofer output measurement?If we need to do this, how to do it? The file is already 0 dBFS.
guofong is offline
post #62 of 85 Old 07-17-15, 08:12 AM Thread Starter
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Okay I get it now, sorry for being so dense.
You went through the process to measure the A/V processor’s subwoofer output, using a 0dBFS signal to get a voltage figure, right? So no, there is no need to add 10 dB to the subwoofer measurement. How do you add dB to a voltage figure anyway?
Here’s the deal: 0 dBFS is the maximum signal the AVP is going to output anyway, right? It can’t generate +10 dBFS - there is no such thing (as far as I know anyway). So, the only way the +10 dB LFE sub output can be achieved is to dial back the main channels by that much. Make sense?
post #63 of 85 Old 07-19-15, 09:34 PM
Many thanks for the reply. This totally makes sense to me.
One more question regrading to the center output measurement:
https://drive.google.com/file/d/0B7-...EycDVtTnc/view
FL 3.45v
C/Pro Logic II music 3.3v
C/Pro Logic II cinema 5V
C/DTS Neo music 4v
C/DTS Neo cinema 5V
As my test results above, the max center output voltage is different when setting different playback mode. Using Pro Logic II music(3.3v) appears to be closed to FL channel output, but which test results is correct?
guofong is offline
post #64 of 85 Old 07-20-15, 04:50 PM Thread Starter
Wow, that’s pretty peculiar. As to which figures are correct, if that’s what you measured with each mode (it never occurred to me to measure any way but with a total bypass!), then they both are correct, funny as that might sound.
The question is though, which figure would you use for gain structuring your system? Obviously, the lower figure. If you gain structure with the Cinema figure, practically-speaking you could end up clipping things when you switch to the Music modes. Assuming you play music as loud as you do movies, that is (I don’t think most people do).
post #65 of 85 Old 07-20-15, 08:09 PM
I totally forget to measure stereo(bypass) mode. Thank you!
guofong is offline
post #66 of 85 Old 07-31-15, 01:55 AM
Hi, Wayne:
I went through the process for Gain Structure.
The clipping indicator of my amplifier begins to blink when I increased the amplifier’s gain control to max. All the channel is the same situation, including my sub amp. Should I set my amplifier’s gain control to max? Is it a good idea to set gain to max? Could it be any danger? I usually set the gain control at around two-thirds of the maximum.
pre amp:EMOTIVA UMC-200
(L/C/R/LS/RS output maximum usable output:1.3v / sub maximum usable output:3.45V)
power amp for L/C/R/LS/RS:QSC DCA 1644/1222
power amp for sub QSC DCA 3022
guofong is offline
post #67 of 85 Old 07-31-15, 09:52 AM Thread Starter
Certainly, the amplifier is going to clip if you turn up the gain controls. It’s perfectly normal. The volume got louder too, didn’t it? That means you’re pushing the amp harder. When amps are pushed too hard, they clip. Clipping shouldn’t be a danger – to the amp anyway (speakers, that’s another issue) – as most professional amps these days have detection systems to shut down if overstressed. However if you followed the gain structure process correctly, then the amplifier gain settings you ended up with are the ones you should use.
post #68 of 85 Old 12-26-15, 08:00 AM
Hi Wayne,
Great guide!!
If one has an AVR with its built in amp(s) driving their speakers and uses a pro-amp to drive their subs. Would this be the right procedure?
Assumptions:
1. Clean output to reference.
2. You have previously eq'ed your sub to where you like it .ie flat or with house curve etc.
1. Disconnect all speakers
2. Turn avr trim up on all speakers in avr
3. Play 0dbfs tone through all speakers, use "All Channel mode"
4. Crank avr to 0db (or cleanest level before distortion)
..now you have max voltage coming out of the avr's sub pre-out....
5. Turn your subs pro-amp input gain up until the indicator flickers red then goes solid red. (Note this setting, don't ever change it)
6. Rerun your room correction in the avr to set your speaker/sub trims in the avr OR use a spl meter to set your speakers and sub trims in your AVR, using your avr's built in tones so that each speaker and your sub are playing 75db at your listening position.
7.Enjoy
Last edited by corradizo; 01-03-16 at 06:53 PM. Reason: Need to play through all speakers not just L and R.
corradizo is online now
post #69 of 85 Old 04-23-16, 05:28 PM
Pending
That was awesone
epk10 is offline
post #70 of 85 Old 03-16-19, 02:55 PM
I read your thread on gain structure. Thank you for the information. I have two questions. In both finding out your avr's clean output and setting your amps gains you say to turn your subwoofers trim up all the way. However, you say "Adjust the AVR’s subwoofer trim level to the maximum setting" in one paragraph and "There’s no need to adjust the AVR’s subwoofer trim, as it will be automatically reduced to “clean voltage” when the AVR’s master volume is turned down to the “clean voltage” setting" in the next. This confuses me. Also, after your done setting your gain you say "All that’s left to do at this point is adjust all the AVR's speaker and subwoofer levels using your usual method". I dont have a usual method. I dont have audicy or any room correcting software nor do i want it. I want to set my sub trim to 0. That brings me to my first question. Can i do everything you said exept keep my subwoofer trim at zero? Im not opposed to turning it up to +15 i just have to know what to set it on after i set my gains. 0? Leave it at +15? My second question is similar to my first. When determining your clean ouput voltage you say to turn your xover to its highest setting. Can i do it with it on 80? Again, im not opposed to setting it to its highest setting, however, i would like to at least put that back to 80 when the test is done to protect my speakers. Thanks wayne!!!
djcreative1 is offline
discussion , gain , home , structure , theater , thread
