Marantz AV7703 Popping Noise - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 14 Old 10-27-17, 08:42 AM
bobbysdad
Re: Marantz AV7703 Popping Noise
I've looked at a pic of the back panel, and the first thing to pop out at me is that it has only a 2 pin power plug. If yours is the same, try connecting an earth wire to the screw connector marked 'Signal Gnd' just left of centre of the back panel, and see what happens.
[oops! sorry for my edits but I was looking at a very small pic….]
bobbysdad is offline
post #12 of 14 Old 10-27-17, 08:51 AM
Power cord with only two plugs is quite normal (without ground)
You need to know that you only have one point to ground, or you might get ground issues as well
Znitz is offline
post #13 of 14 Old 10-27-17, 08:55 AM
bobbysdad
I know that, but that's why they add a ground terminal on audio gear.
In all likely hood, it might not make any difference at all, but it's worth having a shot. I have an amp here that's a bit iffy, and instead of rewiring the whole lot, I found a simple ground wire solved what could've been hours of troubleshooting.
BTW, anywhere else on the planet, and you would have 3 pins. Only in Amerika [and maybe Japan, but many other countries use 240v and grounding the chassis is paramount.]
post #14 of 14 Old 11-05-17, 02:49 PM Thread Starter
SGA
Got another Marantz AV7703 unit from Amazon, this one from a different retailer. Same exact issue. Ran through all the tests, same results.
Either I am unlucky (got two malfunctioning units with same problem) or there is another issue going on here. I'm stumped. Will be returning the second unit. Aggravated, as this unit looks like a real bargain on paper and I was eager to try the Audyssey control app.
sga2
sga2 is offline
av7703 , marantz , noise , popping
