Been out of the game for a while but have been lurking around the forums to slowly get back in to things and see what the latest and greatest is...been using a Behringer ultragain mic2000 for sub pre amp, it finally took a dump and I’m on the prowl for a new preamp for my ep2500 for sub duties. What’s everyone’s recommendations of something under $250 that has input *boosting* for lack of a better work to make sure the pre-out from receiver is strong enough for the ep2500, has some eq possibilities like the mic2200 did, and has an adjustable low and high pass filter? The mic2200 worked fine, I just wished it had a low pass filter since the receiver is set for 120hz or somewhere in that range. Makes things a little peaky with this folded horn and 18” sub. Lol. Any recommendations would be appreciated!
The only thing I’m aware of that will do all that is the vintage Yamaha YDP-2006 parametric equalizer, which you will have to find used (you can find a review in my signature). I think the miniDSP will do everything you’re asking except boost the input signal.
Mini DSP 2x4 Balanced OR Mini DSP 2x4 DL - if you have a 2.1 - Dirac Live can take all that to another level with custom EQ curves and Dirac Live filters - nothing like it !!
I have a MiniDSP-balanced (check the link in my signature). I have used it to drive EP4000 and iNuke6K. You definitely want to get the balanced version. It specifically has the output levels necessary to drive pro equipment. You won't need any other boosting. Guaranteed.
Although it's a bit more expensive than you're speaking of check out the DSpeaker 8033S-II. I'll do far more than just EQ your signal and you can run unbalanced (RCA) to the input and it'll convert to balanced output (requires an adapter cable) into the EP2500. I've always felt that amps with balanced inputs always sound a bit better when the hotter balanced input is used.
Related Threads
742.3K posts
170.9K members
Since 2006
