Best Receiver Advice / Opinions - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 22 Old 01-26-12, 11:06 AM
HTS Moderator
ALMFamily's Avatar
Joe
Re: Best Receiver Advice / Opinions
Just Kurt wrote: View Post
Yeah, still looking. And I can land the Onkyo NR809 for about $100 more than the Marantz and the same price as the NAD. This is overwhelming. I'm sure I'd be happy with either, but still feel the need to make an educated decision. Let me ask this. The Marantz only has pre-outs for FL, FR & Sub whilst the Onkyo provides pre-outs for the entire 7.1 system. How important is factoring this in if I decide to eventually upgrade my system with a power amp. Or is a power amp never really going to be necessary?
A bit late with my 1st post it seems.
Think of it this way - when reading the specs for the 809, you will more than likely see that it says 135W per channel. However, this is not 135W across all seven channels - this is across 2 channels. If you are running a 7.X system, more than likely you will be quite a bit less than 135W when running all seven. That said, you will probably find that if you ever do purchase an amp, your performance will improve dramatically.
So, to use my own as an example, I will be using 2 powered subs that are wired to the sub preouts. I will be running an Emotiva XPA-5 to drive the L/C/R and side surrounds and the 809 will be running the rear surrounds (thus getting 135W per).
ALMFamily is offline
post #12 of 22 Old 01-26-12, 11:17 AM
tonyvdb's Avatar
Tony
The Onkyo's have much larger power supplies than the competition so driving all 7 channels would still do much better than any of the oter manufactures. The Onkyo 609 is rated at 100watts per ch and was benched tested to do better then 85 watts per ch. A lot of receivers loose almost 50% of their rated output when driving all channels. Onkyo has always been very good.
Home theater:
Living room system:
tonyvdb is offline
post #13 of 22 Old 01-26-12, 11:25 AM Thread Starter
Just Kurt
Yeah, I currently live in a relatively small (about 500 sq ft) loft apartment. Due to the layout and room size I am only running a 5.1 system. So I won't be drawing power for a 7.1, but have been told none the less that the Thiels will sound way better being driven by a good power amp. I guess at this point it's a toss up between the Marantz 5006 and the Onkyo NR809.
Just Kurt is offline
post #14 of 22 Old 01-26-12, 11:44 AM
tonyvdb's Avatar
Tony
If its between those two then the 809 is much better, you get THX certification giving you some very useful processing modes, The amp section is much stronger than the Marantz and you get the very best video processing up to 4K something that no other manufacturer gives at this point in that price range.
Home theater:
Living room system:
tonyvdb is offline
post #15 of 22 Old 01-26-12, 12:59 PM
Inactive
Ty
Onkyo will almost always beat a Marantz when it comes to bells whistles and specs, its their forte. However I highly recommend you actually listen to the Marantz as thats their forte.
TypeA is offline
post #16 of 22 Old 01-26-12, 01:40 PM Thread Starter
Just Kurt
See, I'm glad I found this site. Got some good advice and my opinion and options have swayed a bunch. Now it's looking like the winner is gonna be a refurbed Marantz SR6006 from accessories4less.
post #17 of 22 Old 01-26-12, 04:43 PM
MikeBiker's Avatar
Mike
Congratulations on your purchase! The Marantz is well built receivers and should last a long time. Enjoy the better sound that you will get from your Thiels.
MikeBiker is offline
post #18 of 22 Old 01-26-12, 04:55 PM Thread Starter
Just Kurt
Well, haven't purchased anything yet. Still doing some forum hopping. But maybe this is a mistake. Too many opinions start to become overwhelming. But i did find a forum strictly based on the Marantz SR6006 and the reviews are hit or miss. A lot of people seem to really like them, but the same people also complain of several different small issues they have ran into with this AVR.
On the other hand, I found a forum based strictly upon the Onkyo NR809 and hands down, everybody raves about it. I just don't know how much of a difference the sound quality is going to be between the Marantz and the Onkyo. And what makes the $400 price difference of the Marantz worth the extra money?
post #19 of 22 Old 01-26-12, 05:03 PM
HTS Moderator
ALMFamily's Avatar
Joe
Kurt,
I could be wrong (and I usually am - just ask my wife ), but I think once you get to choosing between newer AVRs, there really is no significant difference in sound quality. It really comes down to the features that are most important to you. I think this is the reason you seen so many people raving about the 809 - not only is it packed with features, it also has the best amplifier stage as well as all the preouts.
As many people have said to me - study, make a choice, and don't look back.
post #20 of 22 Old 01-26-12, 05:31 PM
Mike
I tend to disagree that there really is no significant difference in sound quality between receivers. While I have not owned the receivers in question here I did have a Denon 4311, Marantz AV7005 and now own the Onkyo 5508 which IMO just sounded a lot better for movies.
All these are pre-amps (except the Denon 4311 but I used it in pre-amp mode) but the same amp and system was used in the same room of my home.
I would say the Denon and Marantz (which are sister company's) have a laid back sound compared to the Onkyo which might actually favor a Thiel system. If movies are you main concern then I say get the Onkyo, if music is your first priority than the Marantz.
sub_crazy is offline
advice , opinions , receiver
