Denon AVR-4520CI Receiver Review Discussion Thread - Page 14 - Home Theater Forum and Systems - HomeTheaterShack.com
post #131 of 137 Old 04-24-15, 12:03 PM
JBrax's Avatar
Jeff
ellisr63 wrote: View Post
Not yet... I am going to see if i can get a good save, and then try again hopefully today. I think i came up with a better analogy to explain the magic last night... It is like you just stripped the the caramel off of the music, and were left with only the raw music. The sound was 3D, and when you watched a movie the characters were standing in front of you on the stage...the environment wrapped around each individual character to make them real.
I get what you're saying.
JBrax is offline
post #132 of 137 Old 04-24-15, 09:34 PM
New Member
Re: Denon AVR-4520CI Receiver Review Discussion Thread
When you did have the magic what listening mode were you in?
aniceplace is offline
post #133 of 137 Old 04-24-15, 10:42 PM
ellisr63's Avatar
Ron
aniceplace wrote: View Post
It was magic in Stereo (with subs), and when watching movies.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (5) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, Oppo UDP-203, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #134 of 137 Old 04-24-15, 10:45 PM
ellisr63's Avatar
Ron
I think i might have the magic back! I tried again to upload my save and it worked... I then went in and checked the settings just to be sure it was not what i already had, and I saw my inputs were named the same as they were before the reset. I have listened to a few songs and i think all is great! I will do some more serious listening this weekend to confirm, but for now i think I have success. I will need to make backups of backups for the file if it is the correct one.
ellisr63 is offline
post #135 of 137 Old 04-24-15, 10:49 PM
JBrax's Avatar
Jeff
Woo Hoo! The magic is back!
JBrax is offline
post #136 of 137 Old 03-17-16, 07:47 AM
New Member
Long time lurker, new member.
Have what I believe is a straightforward requirement, but can't get a clear answer if the 4520 handles its preamp mode differently than my 4311, with which I'm very pleased overall.
I wish to use my 4311's or a 4520's internal amps to power FL/C/FR and its preamp out for a different 'zone'.
The FL/C/FR and preamp 'zones' use different sources and will not run concurrently, and I wish to turn the Denon's internal amps off when using the preamp and external amp.
My 4311 doesn't have this capability and I'm curious if the 4520 does?
btw, the FL/FR are Studio 60 v5's; great shootout. Thank you.
Edit: Problem solved, operator error.
bmcn is offline
post #137 of 137 Old 03-17-16, 09:38 AM
Rick
bmcn wrote: View Post
I'm running a bit thin on the ground here as I tend not to use the zones on the 4520 but from what I remember the situation is as follows
If you plug anything into a pre-out then the main amp for that channel is muted, someone correct me if I am wrong.
The zones on the 4520 are switchable on and off from the remote, select the zone required (top left button) and switch on or off with that zone selected and whilst it is selected the remote controls the various functions for that zone eg volume etc.
The sources can be selected from the front panel control but are, if memory serves me right, limited depending bythe source mode whether digital, analogue, HDMI or off the internet. I can't remember the exact configuration but as far as I can remember Zone 2 is a low level output from the pre-out, Zone 3 can have any spare amplifier(s) allocated to it and Zone 4 has an HDMI output. There are other functions like being able to drive another AVR using digital or analogue using a different source on the 4520 from which the main zone is set for example CD sound to the other AVR whilst listening to TV sound from the 4520 and there are other features. I have not spent much time on this side of the AVR so some of the information above may be incorrect. The AVR manual is available as a download from the Denon site and may give a better insight into the various zone options, but be warned it is not the easiest manual in the world to read
The other thing is I don't know if the 4520 is still available any more and you may have to look at the 6200 or 7200 but I understand they are a bit more flexible with regard to zone source allocation and conversion from one format to another
Treat all the above with a little bit of caution it is in the ballpark but may not be completely accurate check out the main details from the 4520 manual which can be downloaded here https://usa.denon.com/us/downloads/m...-and-downloads although not easy to go through should give you a good idea of what you can and cannot do, it is quite a large download around 30Mb or more.
Mine is the European model and again from memory there are some differences from the North American model the differences in both cases are all desirable but we don't get em all
Rick R is offline
avr4520ci , denon , discussion , receiver , review , thread
