Denon AVR-4520CI Receiver Review Discussion Thread - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
post #61 of 137 Old 03-17-13, 11:54 PM
8086's Avatar
Guns
Re: Denon AVR-4520CI Receiver Review Discussion Thread
kingpin748 wrote: View Post
I read somewhere that you should do front wide first, that it makes the biggest difference but my space just wouldn't allow it. The wides would be right in the middle of the room just waiting for my kids to knock over.
What would be great is a pair of Paradigm Studio 100s with a CC-690 for the FL, FR, and CC, then move the Monitor 9s to the FWL and FWR. Since I'm dreaming I could pick up that Emotiva XPA3 and use it to run the Studios and put my tiny CC-190 as a front height center running in parallel with the CC-690.
I wonder how that would sound running the same channel into 2 CC at the top and bottom of the screen... Would they blend well or would it be a mess. Considering how different the two centres are it might be a gong show. I wonder what Audyssey would do with that setup? Probably explode.
That Denon amp is work of art. Love the retro mechanical gauges. I wonder if it's any good? It weighs 135lbs! I wonder how much my kidney is worth? I need those Studio 100s and that amp.
Word on the street is that is a worthy contender for its price class and it would be best paired with Signature S8 .
Save the whales?
Naaa... buy local and save your dealer's showroom from permanent extinction!
8086 is offline
post #62 of 137 Old 03-18-13, 12:57 AM
ellisr63's Avatar
Ron
Found this guys setup:
I ran 2 center speakers years ago (one above and one below the screen) and I loved the way it sounded... Of course they were identical centers though.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #63 of 137 Old 03-18-13, 01:26 AM
kingpin748's Avatar
Someone tell me this is a bad idea. I could get another CC-190 for pretty cheap. If I dropped the screen down a few inches the 2nd CC would probably fit above it and I wouldn't even have to run a new wire to the amp, just one behind the screen. Would it mess with the amp running 4ohms for the CC and 8ohms everywhere else? I'm trying to think about why this wouldn't work or sound bad but I'm not coming up with anything. Then again I don't really know that much to begin with.
kingpin748 is offline
post #64 of 137 Old 03-18-13, 10:35 AM
ellisr63's Avatar
Ron
I never had a problem when I did it in the past... When you are playing music across all your speakers the impedance varies by the load and frequency afaik. Since the 4520 will handle a 4 ohm load you should be ok.
ellisr63 is offline
post #65 of 137 Old 03-20-13, 11:28 AM
ellisr63's Avatar
Ron
Question:
I have a WDTV arriving today and was wondering... Do I hook it up to the Media Server input? I was looking at the manual and it didn't say it was compatible with mkv files. The WDTV is compatible with mkv files... Will this effect the Media Server input? Since I have not used it I was thinking maybe there is something special about the Media Server input compared to the other inputs... ie maybe it displays a menu or something.
I also moved from 5.1 to 7.1 yesterday. :-) I decided to take the Paradigm rear speakers and move them up to the side surrounds and take my DCM tf700 speakers (best $50 I have spent in a long time) and put them in the rear corners of the room. All I can say is I have never heard it sound so good! I am going to take some outdoor speakers that I have laying around and make them my height channels until I can afford some Studio 20s for the heights and width channels.
ellisr63 is offline
post #66 of 137 Old 03-20-13, 11:32 AM
tonyvdb's Avatar
Tony
No, just connect it using the HDMI output. The WDTV has its own built in menu. I have two of these running in my house and they work great.
Home theater:
Living room system:
tonyvdb is offline
post #67 of 137 Old 03-20-13, 11:34 AM
tonyvdb's Avatar
Tony
ellisr63 wrote: View Post
......my DCM tf700 speakers (best $50 I have spent in a long time) and put them in the rear corners of the room. All I can say is I have never heard it sound so good!
Ideally you want those to be placed about 4ft apart on the rear wall not in the corners.
Home theater:
Living room system:
tonyvdb is offline
post #68 of 137 Old 03-20-13, 11:47 AM
ellisr63's Avatar
Ron
tonyvdb wrote: View Post
I know but it is in our living room and our seating is against the walls... When I get to building the theater in the garage I will have more room and will do the placement correctly. Currently they are in the location my Dipoles were in. It sounds awesome. I don't know what part of the changes did it but I def like the sound.
ellisr63 is offline
post #69 of 137 Old 03-20-13, 11:49 AM
ellisr63's Avatar
Ron
Thanks, I have heard nothing but good about them... I can't wait to get them installed. Is the Media Server input a special one or is it the same as all the other HDMI inputs?
ellisr63 is offline
post #70 of 137 Old 03-20-13, 12:25 PM
tonyvdb's Avatar
Tony
If your asking the input on the WDTV unit? its either Wi-Fi network connection or cat5e to the PC or you can just connect a 1 or 2 TB USB hard drive to it with all the media you have on it.
Home theater:
Living room system:
tonyvdb is offline
avr4520ci , denon , discussion , receiver , review , thread
