Denon AVR-4520CI Receiver Review Discussion Thread - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
post #71 of 137 Old 03-20-13, 12:39 PM
ellisr63's Avatar
Ron
Re: Denon AVR-4520CI Receiver Review Discussion Thread
tonyvdb wrote: View Post
If your asking the input on the WDTV unit? its either Wi-Fi network connection or cat5e to the PC or you can just connect a 1 or 2 TB USB hard drive to it with all the media you have on it.
No, I meant the input labeled Media Server on the 4520... Is it just a standard HDMI input? In the manual it lists what can be played on it.
I will have to go checkout some cases that I can hookup my SATA 4TB hard drive to that are USB.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #72 of 137 Old 03-20-13, 12:47 PM
tonyvdb's Avatar
Tony
I dont think so, Its more designed to plug a hard drive directly to it.
Home theater:
Living room system:
tonyvdb is offline
post #73 of 137 Old 03-20-13, 02:33 PM
kingpin748's Avatar
ellisr63 wrote: View Post
Thanks, I have heard nothing but good about them... I can't wait to get them installed. Is the Media Server input a special one or is it the same as all the other HDMI inputs?
Its the same as the other ones. Not sure why the bother labeling them anymore as you can just rename in the settings. Should just leave them as "1", "2", etc...
You've got the right idea with the USB enclosure as many people do that. Your other option is to go wireless or use a LAN cable and stream right from your computer to the WDTV to the Denon.
The Denon by itself will not play .mkv as far as I can tell from the manual. If you're looking to hook up that drive to the Denon you'll only be able to play what's listed on page 47 of the manual. If you hook the drive up to the WDTV you can play basically anything with a GUI that is far superior to what the Denon has.
So USB Drive to the WDTV then HDMI to Denon. Then you get to play around with the WDTV and set it up but that's well covered in other threads and forums.
kingpin748 is offline
post #74 of 137 Old 03-23-13, 09:12 AM
ellisr63's Avatar
Ron
Does anyone know of a Demo for 9.1 audio? It would be nice to have a demo video that shows what 9.1 is capable of.
ellisr63 is offline
post #75 of 137 Old 03-23-13, 09:28 AM
tonyvdb's Avatar
Tony
There is no "true" discreet 9.1 audio mix available. What happens is the receiver will matrix the extra 2 channels basically making an educated guess as to what should be sent to those two channels.
Home theater:
Living room system:
tonyvdb is offline
post #76 of 137 Old 03-23-13, 08:31 PM
phillihp23's Avatar
I love my 9.2 and can't wait to add for 11.2
Once you have it its hard to do without.
Home Theater System Denon AVR4520CI, Emotiva XPA-5 Gen 2, Polk CSi A6 Center, Polk RTi A9 Front, Polk RTi A7 Front Wide, Polk RTi A1 Front Height, Polk FXi A6 Side, Polk RTi A3 Rear, SVS PB12-NSD x2 Front, SVS PC12-NSD x2 Rear, Panasonic PT-AE7000U, Visual Apex CineWhite 100" Screen, PS4, Dish Hopper, Darbee Darblet DVP 5000.My Home Theater Build
phillihp23 is offline
post #77 of 137 Old 03-24-13, 12:08 AM
kingpin748's Avatar
The best you can get is something like The Expendables 2 which apparently has been "optimized" for 11.1 audio, whatever that means.... As far as I know there isn't even an agreed upon format for delivering more than discrete 7.1 audio right now.
post #78 of 137 Old 03-24-13, 02:51 AM
ellisr63's Avatar
Ron
kingpin748 wrote: View Post
What a shame that there are no demo discs to show off all the channels.
ellisr63 is offline
post #79 of 137 Old 04-09-13, 08:06 PM
nezff's Avatar
hey guys. long time no talk. Im in the market for a Denon 4520 or Marantz 8801. Im wondering what you guys opinions are. Im seeing some issues with reliability on the 4520 over at the AVS forums. Just wondering if any of you guys have had repairs or returns etc..
thanks
nezff is offline
post #80 of 137 Old 04-09-13, 10:23 PM
Jerry
nezff wrote: View Post
thanks
I have the 4520, and it is rock solid. I am also a frequent participant in the AVS 4520 thread. There are some recent complaints, but keep in mind that happy users don't usually post their happiness. Also note that several of the posters reporting issues purchased refurb units.
AFAIK, you currently own the 8801, and previously owned the 4520. You even stated that you heard no sonic difference between the two. What is the purpose of your post?
AustinJerry is offline
avr4520ci , denon , discussion , receiver , review , thread
