Speaker wire - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 03-17-13, 11:13 AM Thread Starter
Speaker wire
What's the best speaker wire to use for klipsch surround sound ?
David831 is offline
post #2 of 11 Old 03-17-13, 12:28 PM
Jungle Jack's Avatar
Jack
Re: Speaker wire
David831 wrote: View Post
Hello,
Most of us find that something from Monoprice will offer you the same performance as using much more expensive speaker cable. That being said, I personally decided to use factory terminated speaker cable as it does make connections much easier. Also, if needing to use a long cable run for the Surrounds or any other speaker, getting a thicker cable is advisable. What Klipschs are you using?
Best,
J
HT
Speakers: Martin Logan Vantage (Mains), Martin Logan Stage (Center), Martin Logan Vista (Surrounds), Martin Logan Montages (Surrounds) Hsu Research VTF-15h MK2, Martin Logan Descent i (Subwoofer)
Amplification: Aragon 8008bb, Parasound HCA-3500, Parasound HCA-2205 AT, Parasound HCA-1000a
AVR/SSP: Denon AVR-4520CI
Electronics: OPPO BDP-93
Gaming Consoles: Sony PS4, Xbox 360 S (250 gb)
Display: Panasonic TC-P65ZT60, Sony KDL-55EX500, Sony KD-34XBR910
Jungle Jack is offline
post #3 of 11 Old 03-17-13, 01:03 PM Thread Starter
Re: Speaker wire
I just got there more basic set up the hdt600
David831 is offline
post #4 of 11 Old 03-17-13, 01:32 PM
B- one's Avatar
Brandon
Are you going to run wiring in the walls? Of so you might want to use wire rated for that purpose to avoid possible building code violations. Not sure but but I did that to play it safe it's 16 gauge unfortunately I had to buy two rolls was about ten feet short with one.
B- one is offline
post #5 of 11 Old 03-17-13, 01:52 PM
Bob
Re: Speaker wire
Jungle Jack mentioned Monoprice which is good cable. I've also used Parts Express as a speaker cable source. Their cable is comparable and they have different sizes and types to offer.
A question relating to size: how long is your run to the speakers? That's an important determiner for the gauge to use.
RBTO is offline
post #6 of 11 Old 03-17-13, 01:57 PM Thread Starter
Re: Speaker wire
The front 3 speakers will be a 40' run
David831 is offline
post #7 of 11 Old 03-17-13, 05:17 PM
hjones4841's Avatar
Silly Girl!
Re: Speaker wire
Be careful about advertised wire "gauge." If it says AWG gauge, that is the best to buy. Otherwise, "gauge" is whatever the manufacturer (usually in China) wants it to be. For instance, I bought some 12 "gauge" wire a while back that was smaller in diameter than AWG # 16.
Also note the wire material used in construction. Pure copper is best. Copper coated steel, not so much - it will have a higher resistance than pure copper. Not sure that anyone can tell the difference in what is advertised as oxygen free copper, so I would not pay much more for it.
Hug your pet today!
hjones4841 is offline
post #8 of 11 Old 03-18-13, 01:52 AM
kingpin748's Avatar
I've used 14awg in wall speaker wire for a 9.1 setup I just did. Some of the runs were 30' at least and I'm running some Paradigm speakers off at Denon 4520. I suspect you would be fine with 16awg for what you want but I would do 14awg.
kingpin748 is offline
post #9 of 11 Old 03-19-13, 06:52 PM
Bob
Re: Speaker wire
kingpin748 wrote: View Post
I'd agree. That's 80 feet round trip so I'd err on the larger size wire rather than smaller. You may want to run higher power or lower impedance speakers later on, and #14 would handle that situation.
RBTO is offline
post #10 of 11 Old 03-19-13, 07:04 PM
Inactive
Re: Speaker wire
I have a 50' run of Monoprice 12ga. in-wall speaker wire for each of my rear surrounds. Good price, works great.
86eldel68-deactivated is offline
speaker , wire
