-   Home Theater Receivers | Processors | Amps (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/)
-   -   NAD & Dirac Live (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/169594-nad-dirac-live.html)
Kal Rubinson 07-04-17 09:11 PM
Re: NAD & Dirac Live
RTS100x5 wrote: (Post 1583274)
Easily fixed by putting this 5 port switch in front of it...using the same one in mybuddys 15k system ...works like a champ and has discreet codes...
for HDMI sources only.
RTS100x5 07-04-17 09:34 PM
Kal Rubinson wrote: (Post 1583290)
for HDMI sources.
yes he now has 5 sources passing through the NANO AVR DL
typ44q 07-05-17 07:29 AM
RTS100x5 wrote: (Post 1583298)
But it is still only HDMI v1.4 so no 4K, HDR, HDCP 2.2 etc
an updated version of that with atmos support would be great
bommai 07-12-17 04:39 PM
Kal had asked earlier about BM. The miniDSP product does not have bass management at all. Which means, you will have to do it in the receiver/processor. Since the sources are typically connected to the miniDSP product, BM happens after Dirac instead of before (which is what I was told is ideal).
Also the miniDSP product does not have any decoders which means all audio that gets there better be in PCM format.
bommai 07-14-17 10:04 AM
NAD T758 v3 with Dirac Live, Atmos, and 4K for $1200 is out. Dirac Live is a future firmware upgrade though.
nathan_h 09-03-17 01:23 AM
No dts -x support, right?
nathan_h 09-07-17 08:15 PM
And where is it going for $1200? Crutchfield lists $1300.
