-   Home Theater Receivers | Processors | Amps (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/)
-   -   TX-SR444 audio issues. audio only works on zone a. (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/169697-tx-sr444-audio-issues-audio-only-works-zone.html)
Princess 07-05-17 07:44 PM
So I don't believe I even had this for a year and it was new and it is already having issues. It started having the audio cut in and out for a few seconds a few times a day and I ignored it. Now it only goes through 2 speakers and the subwoofer and for whatever reason audio only works on zone a. if I try and change the settings like to mono, stereo etc it just says "zone off" forcing me to put it on. I even did a 7.1 test in the speaker set up on my pc and all the 7 sounds come out of the 2 speakers instead of 7. Yes I did a factory reset. It does this to every channel. I tried my ps4 as well.
selden 07-07-17 12:55 PM
Re: TX-SR444 audio issues. audio only works on zone a.
Sadly, that means that you need to contact their customer support and arrange to get it repaired. If it's out of warranty, it'll probably be less expensive to buy a replacement. However, most credit cards double the original manufacturer's warranty period, so check that.
