-   Home Theater Receivers | Processors | Amps (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/)
-   -   Newb needs help with subwoofer amp (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/174670-newb-needs-help-subwoofer-amp.html)
Springheel 06-22-18 01:16 PM
Hi everyone. I recently replaced an old RCA home theatre in a box with a new Yamaha RX-V385BL receiver.
I didn't know anything about the difference between passive and active subwoofers, but have since learned the receiver has only an RCA pre-out connection. My old RTD150 subwoofer is a passive sub.
What I've gathered is that I need to either buy a powered sub (which would cost nearly 2/3 of what I spent on the reciever) or get an amp.
After a couple hours of searching online, I can't make heads or tails of what kind of amp I would need, so I can't even begin to judge whether that would be the cheaper way to go.
Would it be cheaper to look into returning the receiver and buying one that can handle a passive sub?
Can anyone offer some advice? If it helps, it's a fairly small room and my audio tastes are not at all discerning. I'd just like decent bass when listening to movies.
Thanks in advance.
Kal Rubinson 06-22-18 04:06 PM
Re: Newb needs help with subwoofer amp
Springheel wrote: (Post 1610246)
No. All decent receivers have RCA outputs for subs. The only ones that do not are receivers that are part of a "Home Theater in a Box" system.
RTS100x5 06-25-18 06:04 PM
This amp will drive your subwoofer and is pretty inexpensive ...It just needs to be wired to your subwoofer . then use an RCA cable to plug it in to your new receiver SUB OUT.
https://www.parts-express.com/yung-s...boost--301-504
