-   Home Theater Receivers | Processors | Amps (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/)
-   -   Sherwood/Newcastle R-972 Official Thread (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/55399-sherwood-newcastle-r-972-official-thread.html)
tonyvdb 02-23-12 09:51 PM
Well I got my R-972 today from accessories4less (that shipped to me from Florida to Edmonton Canada in just 2 days!) and had an hour to hook it up and play with it just a little.
First impressions are is that it was probably one of the best investments I could have made :)
Out of the box this receiver is huge! the weight is about 45lbs although Ive red conflicting reports that it weighs as much as 60lbs. No matter how you look at it its a beast for size and covers the top shelf of my AV rack completely and its very tall for a receiver.
I hooked all my gear up to it and the main speakers (I plan only using this as a two channel setup) I then powered it up and it came to life without any issues (First sigh of releaf given the distance it traveled). Without even having time to do any of the settings or even running Trinnov I played my iPod and could not believe the clarity of the sound, It brought my Missions to life it seems. they were clean and like my EV sentrys downstairs sounded much more dynamic and the separation was outstanding!
Im going to spend some more time playing tomorrow but for now I am thrilled by what its done even without any room eq applied :T
To check the version of your R-972 firmware:
hold Display and Enter/Memo
To reset the R-972 to factory settings:
Once in Standby Mode, press and hold down the STANDBY & MEMO/ENTER buttons simultaneously for at least 3 seconds. This will reset the unit and it will turn on automatically. If the reset was successful, you should notice that the receiver powers up at 87.5 FM . If not, repeat the reset process.
Information on installing the bass boost Hex files here
Jungle Jack 02-23-12 09:58 PM
Re: Sherwood/Newcastle R-972 impressions
Tony,
I am so glad you are pleased with the 972. The longer I have it, the more I am convinced it is one the greatest values for an AVR I have ever come across and truly feel blessed to have one.
Cheers,
J
ALMFamily 02-23-12 10:00 PM
That is great to hear Tony! I am having delusions of grandeur that mine will arive tomorrow. One downside, I have to hook it up to my Acoutimass 10 for now...... :sob:
On the plus side, the boys and I went down and watched Batman Begins tonight - oh wow I can't wait to finish my room and get that equipment going in a sealed room.....
tonyvdb 02-23-12 10:18 PM
Thanks Jack and Joe. I am really impressed with it so far. I am again in the mindset that spending the money on a good quality receiver "and" speakers not just speakers is a must in order to really get the sound that the recording artists intended you to hear. I do not believe that a pre-pro is of any real value any more when you can get a unit like this for $600 brand new!
ALMFamily 02-23-12 10:32 PM
Based on your impressions, I may just have to lug this down and swap it in for my 809 to see what they sound like with my EmpTek i55 towers.
tonyvdb 02-23-12 10:39 PM
Im not really sure there would be much difference between the two as the 809 is not at all a low end receiver either. My 805 is not going anywhere either, I just believe that the Marantz 6005 that I was using was not in the same liege but it was a step up from the Yamaha RXV995 that I used before it .
Jungle Jack 02-23-12 11:58 PM
Joe,
I would list the Acoustimass on Craigslist tonight or tomorrow. To the unwashed masses, Bose holds a great amount of cachet. Thanks to this, you should be able to get a decent return of your investment to allocate towards vastly superior Speakers. I am quite confident we could help you get a vastly better Speaker Array for not much more than the proceeds from selling the Bose. I would guess you could even sell them to a friend or family member.]JJ
jaymz 02-24-12 07:59 AM
Well, I ordered this thing yesterday afternoon. I've been lusting after the Marantz SR7005, but I know that at $1300, I would never really be able to afford one. I really can't afford the 972 either, but simply could not resist the opportunity. I already own a couple other Sherwood Newcastle receivers (771 & 772) for bedroom and wifey's living room system; I find them to be a bit odd, but they work). I'm buying the R972 to replace my Marantz SR7300 in the main veiwing room. Does anyone know if the 972 will passthru an HDMI signal to my TV when power is off?
Jim
tonyvdb 02-24-12 08:26 AM
Hi Jim, The 972 will easily blow the doors off the Marantz 7005 so you made a very good choice. I dont have a HDMI capable display hooked up to my 972 so I can not confirm if it will pass HDMI video when off however I will see if it passes Component (when I get home tonight) as thats what I use, chances is if it does it will also pass HDMI
ALMFamily 02-24-12 08:38 AM
Jungle Jack wrote: (Post 500998)
Joe,
I have seen several times where you have been able to suggest a very good system for very reasonable cost - challenge accepted! I think I will package my 604 and the Bose system and see if I can move them.....
