-   Home Theater Receivers | Processors | Amps (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/)
-   -   Onkyo 805 and Apple TV zone 2 set up (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/67315-onkyo-805-apple-tv-zone-2-set-up.html)
JAKE 2544 05-04-13 11:10 AM
I'm trying to use my zone 2 outside speakers to play either Apple TV radio or pandora using Apple TV on my tx-sr805 but can't get it to play . It works fine on zone 1, I'm using aux1 on the receiver for Apple TV. Zone 2 works fine on the tuner but when I switch to aux1 nothing. The user manual for the receiver says only analog input sources are output by zone 2 so does this mean the Apple TV won't work on zone 2? And is my only option for outside music on zone 2 the tuner / fm radio. Thanks for any info and help.
RTS100x5 05-04-13 07:11 PM
Re: Onkyo 805 and Apple TV zone 2 set up
Not at all ... You need a DIGITAL to ANALOG CONVERTER ...easily had from Radio Shack or FRY's
http://www.radioshack.com/product/in...uctId=12075975
This is the one we use in all our installations and it works like a champ
http://www.amazon.com/Digital-Audio-...udio+converter
If you need help setting it up just PM me...but its very simple to use...
