-   Home Theater Receivers | Processors | Amps (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/)
-   -   Bose speakers with Yamaha receiver (https://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/68709-bose-speakers-yamaha-receiver.html)
kenbola 07-22-13 10:17 PM
To all my HT gurus:
I have a Bose Lifestyle 28 Series 3 DVD Home Entertainment system (5.1). The Bose speakers are mounted on the ceiling. I would like to hook up the speakers and the subwoofer to a Yamaha RX-V475 receiver. Do you see any issues doing this? Will this receiver be compatible with these speakers/sub? Thanks for your help
tonyvdb 07-22-13 10:22 PM
Re: Bose speakers with Yamaha receiver
If the speakers have normal two wire connections and the sub has its own line level input (rca) you should be good to go.
kenbola 07-23-13 02:22 PM
Tony- Thanks soooo much for the quick response. The speaker wire can easily be spliced and connected to a non-Bose receiver. The subwoofer has a proprietary cable and it doesn't look like there is any way to connect the subwoofer to a non-bose receiver. Also, do I have to be concerned about the ohms of the Bose speakers versus ohms limitations on the receiver? thanks again.
Kenbola
tonyvdb 07-23-13 02:29 PM
Given the size of the Bose satellite speakers, no I would not worry about the Ohms on them. My concern is the so called sub if it does not have a normal input then you wont be able to use it.
chashint 07-23-13 04:44 PM
Size of the speakers has no bearing on their impedance or sensitivity.
Having said that it is unlikely the Bose satellites are hard to drive.
It will be interesting to find out what you think of the sound once you replace the electronics and Acoustimass module.
Whatever engineering went into the speakers was for all the pieces to work as a system.
kenbola 07-24-13 08:26 PM
spoke to Bose technician. The Lifestyle system (speakers and acoustimass module) are not designed to separate out the speakers from the rest of the system. The speakers need the feed from the acoustimass module. He says u can TRY and use the speakers with another receiver, but no guarantees it will work or how long the speakers will last. There are some bose 5.1 speakers designed for use with non-bose receiver but they are stand alone speaker systems.
RTS100x5 07-27-13 05:04 PM
I have used Bose cubes w other AVR's in several installs...for whatever reason .... they all worked well but I made sure to set the x-over at 120hz... your better off not using to Acoustimass module unless its one of the older ones with RCA input... I have hacked into one that didnt and its a pain but can be done... That being said of course the Bose tech is going to tell you that their speaker system is proprietary.... but we know it just aint so :D
tcarcio 07-27-13 05:56 PM
For the time and effort you will put into trying to get the bose to work with your yamaha I think you would be better off just getting some decent used bookshelf speakers. They would probably sound better too. I have the bose 321 system in my living room because of the wife not wanting a bigger system and I wouldn't want to use them any other way. Just my 2 cents, Good luck..:D
kenbola 07-28-13 10:10 AM
Thanks so much for your input. As an installer- I now know it isn't worth it trying to make my customer's bose speakers "work" with another receiver. For now we are going to use his current system- use an optical (toslink) cable and a procontrol remote. that's the latest- will keep you posted.
eyespy39 08-24-13 05:17 PM
I once had a Bose Lifestyle 1-2-3 system due to its wife acceptance factor (small footprint, esp. the cubes). I had bought it as a replacement for a cheap'n dirty Sony 5.1 home system, so the sound was really better. But there were software issues and power line hum even when the system was turned off due to the acoustic mass module that could not be turned off completely.
That was my chance to return it to the dealer, so I bought a Harman Kardon AVR 235 plus JBL Beta HCS Speakers, instead. And even if that AVR and the boxes were not top of the line then, the system sounded still much better than Bose. True, the Cubes sound way bigger than they are. But I believe now that all the DSP-genereated psychoacoustic wizardry by Bose can never fully make up for the qualities of well made speakers and decent setup AVRs/Processors/Amps.
The conventional Harman-Kardon/JBL 5.1 system was less expensive, by the way. Plus, its blue-lit volume dial appealed to my spouse, too.
I've never regretted leaving Bose, even though I upgraded my system a bit by now…
just my 2 cents
