Trying to update but super confused - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 04-05-11, 11:19 PM Thread Starter
Question Trying to update but super confused
Here's the deal: My receiver and TV are practically antiques. I like my music to sound good, and I want a TV that's acceptable to invite friends over for the occasional movie - I don't watch much TV otherwise. My budget is limited but has some flexibility, and I'm willing to buy used. I don't want to make the living room look ugly or annoy my neighbors.
I thought that since everything is now digital I could skip the receiver and get one box to take input from an MP3 player, CDs, DVDs and Blu-Ray, and output to speakers and TV. However, I don't see anything so simple.
Also, surround sound apparently isn't needed for someone who cares more about music than movies, but everything seems to be surround. How am I supposed to arrange 5+ speakers in a small living room?
The TV sizes seem out of whack, too, since I still live with a tube... what's the smallest flat screen you would recommend to enjoy decent looking movie in a small living room? Is LED worthwhile?
Anyone have products to recommend? Or am I missing the right keywords to search? Thanks!
cateye5 is offline
post #2 of 11 Old 04-05-11, 11:35 PM
Mike P.'s Avatar
Mike
Re: Trying to update but super confused
Welcome!
What size is your living room and what is the distance from the couch to the TV's location?
We're all in this together!
Mike P. is offline
post #3 of 11 Old 04-05-11, 11:56 PM Thread Starter
Thanks! 14 x 16 feet with TV and couch about 10 feet apart.
cateye5 is offline
post #4 of 11 Old 04-06-11, 01:20 AM
Glenn
There's nothing wrong with listening to movies in stereo if you don't want full surround sound. Doing a 2.0 or 3.0 set up instead of a 5.1 would leave alot more money to buy better quality speakers.
If you have neighbors that can be easily annoyed, I would use full range tower speakers that can play well below the 40hz range instead of using a subwoofer that can easily rattle neighbors. Also better for music.
Using a full 5.1 or 7.1 surround sound set up has nothing to do with room size. It can be used in rooms smaller than yours.
gdstupak is offline
post #5 of 11 Old 04-06-11, 05:11 AM Thread Starter
Phrases like "full range tower speakers" are exactly what I'm looking for, thanks.
So I'm looking at replacing my old Nak receiver with a current one that also handles MP3 and possibly internet input (Onkyo seems like the brand most recommended?), replacing my CD/DVD player with one that handles Blu-Ray, and picking up 2-3 speakers -- what brand(s) are recommended for the speakers? I'll probably need some kind of wall mounts to keep them from the cats.
Apparently the world has changed less than I thought.
cateye5 is offline
post #6 of 11 Old 04-06-11, 09:13 AM
Glenn
For now, I would go with 3 identical speakers for left, right, and center. If you get interested in surround sound, you can always add rear speakers later. Having a center speaker can help to anchor sound to the center of the screen.
For 3 speakers, what would be your budget?
$1500 for all 3.... or $800 for all 3..... or $400 for all 3.
What kind of budget are you wanting for a AVR (audio video receiver)?
$1500 is very good.... $800 is good..... $300 is entry level.
What kind of budget for tv?
$2500..... or $1200.... or under $900.
gdstupak is offline
post #7 of 11 Old 04-06-11, 09:25 AM
Jungle Jack's Avatar
Jack
Hello,
Adding a new TV and an AVR and Speakers need not cost a fortune. For a TV, this 55" LCD Model really has surpassed my expectations and is relatively inexpensive for the money:http://www.bestbuy.com/site/Sony+-+B...&skuId=9763163
Check out the User Reviews of which there are many. This TV was originally 2500 Dollars when introduced.
For an AVR, something like this would work nicely:http://www.accessories4less.com/make...eceiver/1.html
It is available for 50% off and is still a current model.
For Speakers, SVS's SBS-01 at 100 Dollars off is an awesome deal and you can just start off with 2 if need be:http://www.svsound.com/products-spks-sbs01.cfm
For Cables go to Monoprice or Bluejeanscable.com and save a fortune and you are good to go.
Cheers,
JJ
HT
Speakers: Martin Logan Vantage (Mains), Martin Logan Stage (Center), Martin Logan Vista (Surrounds), Martin Logan Montages (Surrounds) Hsu Research VTF-15h MK2, Martin Logan Descent i (Subwoofer)
Amplification: Aragon 8008bb, Parasound HCA-3500, Parasound HCA-2205 AT, Parasound HCA-1000a
AVR/SSP: Denon AVR-4520CI
Electronics: OPPO BDP-93
Gaming Consoles: Sony PS4, Xbox 360 S (250 gb)
Display: Panasonic TC-P65ZT60, Sony KDL-55EX500, Sony KD-34XBR910
Jungle Jack is offline
post #8 of 11 Old 04-06-11, 09:28 AM Thread Starter
Budget... for the speakers I'd say $400-800. Since speakers are long-lasting I was hoping to find something on Craigslist.
I'm thinking mid-range or ~$500 on the receiver, but I can go to $800 if it will give me something that will last longer. I'm a little more hesitant to get that used.
TV definitely under $900.
Thanks.
cateye5 is offline
post #9 of 11 Old 04-06-11, 09:33 AM Thread Starter
Jack, that AVR looks perfect and so does the price, thanks.
Your TV link isn't working, can you tell me which model that was?
cateye5 is offline
post #10 of 11 Old 04-06-11, 10:34 AM
Jack
Hello,
The link is for the Sony KDL-55EX500. I will try to link it again, if not just enter the Model Number into Google and Best Buy is the first hit : http://www.bestbuy.com/site/Sony+-+B...&skuId=9763163
I tried the link and it does not work. Weird.
Cheers,
JJ
HT
confused , super , update
