Living room setup advice appreciated - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 42 Old 07-28-12, 12:58 PM
Jungle Jack's Avatar
Jack
Re: Living room setup advice appreciated
showcattleguy wrote: View Post
How about another HSU sub? Can never have to many.
Great call. At least the remaining budget is being put towards upgrading the Loudspeakers which is the 1a or 1b to adding a 2nd VTF-2.
HT
Speakers: Martin Logan Vantage (Mains), Martin Logan Stage (Center), Martin Logan Vista (Surrounds), Martin Logan Montages (Surrounds) Hsu Research VTF-15h MK2, Martin Logan Descent i (Subwoofer)
Amplification: Aragon 8008bb, Parasound HCA-3500, Parasound HCA-2205 AT, Parasound HCA-1000a
AVR/SSP: Denon AVR-4520CI
Electronics: OPPO BDP-93
Gaming Consoles: Sony PS4, Xbox 360 S (250 gb)
Display: Panasonic TC-P65ZT60, Sony KDL-55EX500, Sony KD-34XBR910
Jungle Jack is offline
post #32 of 42 Old 07-29-12, 01:12 AM Thread Starter
Jungle Jack wrote: View Post
Ah I actually just placed the order from svs (started getting a little afraid that somehow the sale would end) for 2 pairs of scs-02 mains, scs-02 center, and a pair of sbs-02 for heights. Upgrading to the scs-02s for fronts and heights was only $200 more (when I had $300 left), but adding a second VTF-2 would put me over... I guess that could be the next thing I work towards (also depending on how much I sell my old stuff).
Thanks guys! I'm so excited for the speakers; don't know what I'm going to do having to just see them sitting in their boxes in my apt for 4 months..... I'll have to hide them away haha
vyyv is offline
post #33 of 42 Old 07-29-12, 02:19 PM Thread Starter
Thinking about the speakers, I have another question about placement for the surrounds. Where I'll be sitting, there is no right wall. The separation is kind of like an "archway," where there is a little bit of overhang. This means I could (1) either get brackets to mount the two surrounds up high (around 8 ft) and angle them towards the sofa, (2) put them on speaker stands/mount in the rear corners of the room (which would seem to result in a larger angle than prescribed for surrounds), or (3) mount them on the rear wall.
Which is preferable acoustically? (mainly high up just a little behind the seating area, or at ear level, but at a sharper angle)
vyyv is offline
post #34 of 42 Old 08-01-12, 08:38 PM Thread Starter
Hello,
Congratulations on the Condo. For $5000, we can help you put together a stellar HT. While I do think Polk makes a quality Speaker, I would personally sell them and put the proceeds towards the project.
As hjones pointed out, Ambient Light must be hugely attenuated for a Projector to operate properly. Otherwise, the Picture will be completely washed out during any Daytime Viewing such as watching NCAA/NFL Games on the Weekend.
If you have a space that can be made completely dark, Projectors are just an amazing experience and after watching a 100" Screen at home, it is next to impossible to be happy with anything else.
That being said, a Projector and Retractable Screen is going to represent a very large amount of your budget.
If Ambient Light is an issue, Mitsubishi's DLP Microdisplays are quite cost effective and work great in Rooms where light is an issue. For instance, for $1899 you can get a 3D 73 inch Mitsubishi Diamond from Best Buy that is actually sold at their upscale Magnolia Home Theater Area:http://www.bestbuy.com/site/Mitsubis...ishi&cp=2&lp=1
Truth be told, if purchased Online you could get that TV for even less. Also, Mitsubishi makes a 92 Inch Microdisplay as well, but it would eat up too much of your budget. However, it might be possible for find a 2011 92 Inch Mitsubishi heavily discounted Online. Another great thing about Mitsubishi is they only charge $99 for a Replacement Lamp whereas many Projector Lamps cost close to $300.
Regardless of which direction you decide to go, we will do everything possible to help you.
Cheers,
JJ
I actually have a new question - previously, I was pretty set on the mitsubishi, but today, I went to look at a friend's setup with an Epson Powerlite 8350 projector, and even with ambient light (as well as almost direct light) + just being projected on a white wall, I actually found it to be reasonable (especially when we put it on a higher setting). Since I will watch primarily at night + I'll get room darkening honeycomb shades, I was just wondering how much a nice projector + screen combination would actually cost, or alternatively, how nice a projector + screen could I get for around $2600 (i.e. the price of the tv). Note that I would need to get a retractable screen, which JJ mentioned could be kind of pricey. I just wanted to get some more information + do some more research before finalizing my decisions.
Any help on this would be amazing! Thanks everyone!
vyyv is offline
post #35 of 42 Old 08-01-12, 08:53 PM
Jack
Hello,
While it will slightly take you over budget, the Sony VPL-30HWES SXRD Projector is available currently for $2649 at Amazon. It has won countless awards and is honestly quite impressive as I have recommended it to several friends.
As for a Screen, you have many choices ranging from DIY to come closer to reaching your budget or Da-Lite, Stewart and many others make excellent Projector Screens.
Cheers,
J
HT
post #36 of 42 Old 08-02-12, 02:58 PM Thread Starter
Hello,
Cheers,
J
Ah I see - so the tv would be quite a bit more cost effective as well - I think I'll stick with that then. Thanks JJ!
vyyv is offline
post #37 of 42 Old 08-02-12, 03:20 PM
Jack
Hello,
Well there certainly are cheaper Projectors. I just think if you are going to do it, get the best you can possibly afford. The Sony is really special and some Projection Screens are fairly inexpensive and would not take you too far off your budget. And of course you could get a less expensive DLP or LCD Projector and easily meet your stated budget. It is just after seeing the HW30ES many times, the Black Levels are so good that it is hard for me to recommend anything else near its price.
Cheers,
JJ
HT
post #38 of 42 Old 08-02-12, 06:01 PM Thread Starter
Thanks JJ! The projector would definitely be nice, but since I would also have to get a motorized screen (that would be reasonable even in ambient light), the cost would be quite a bit higher. If I ended up getting a less expensive projector with lower quality, I might as well stick with the Mitsubishi TV (which seems to have quite good picture quality as well?). I just wanted to better understand my options - if I'm ever able to get a dedicated room + save up more, of course I would choose the best I could afford. I was only wondering if there would be an option that would be priced around the tv, but offered better picture quality. The Sony may very well be, but together with the screen, would also cost much more.
Going back to speaker placement though (just in case someone has some insight) - in a dsx (heights 7.1) setup, if it is difficult for me to put the surrounds on speaker stands, would it be better if I ceiling mounted at the right angle, or put them in the back corners?
vyyv is offline
post #39 of 42 Old 08-02-12, 07:16 PM
Jack
vyyv wrote: View Post
Hello,
I would at least try the back corner before going In Wall. I am honestly impressed with the Mitsubishi DLP's for their value and for being the only company to stick with Microdisplays. In addition, I love that Mitsubishi only charges $99 for a Replacement Lamp whereas Front Projector Lamps can cost a small fortune.
Cheers,
JJ
HT
post #40 of 42 Old 08-03-12, 12:38 PM Thread Starter
Hello,
Cheers,
JJ
Yeah I think I'll stick with the tv for now + try out different locations for the speakers once I move in.
Earlier, someone did recommend adding an extra subwoofer. Do you think it would make a big difference in my room? I'm planning on getting the HSU VTF-2 MK4 you recommended, but 2 of them would get pretty expensive - would it be more preferable to just stick with the MK4 or get two smaller, cheaper subwoofers?
vyyv is offline
advice , appreciated , living , room , setup
