Denon 2809 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 34 Old 06-02-13, 06:09 PM Thread Starter
Tom
Denon 2809
I am a newbie. I have had this Denon 2809CI for some time now. But, when I play it loud it will shut down in 5-10 mins. Since new. I have Deftek BP7006 front, Deftek BP2002 center, and Deftek BP (?) 2004? ( bookshelf ) can not find the model# on them. I am looking at upgrading to a Denon 4520 or 3313. Any suggestions? Or something that can drive these speakers like they are meant to be?
tgeary00 is offline
post #2 of 34 Old 06-02-13, 07:53 PM
bamabum's Avatar
I have the 3313ci and love it. You have to do firmware updates I've found for optimal performance. I power deftechs in a 7.2 and it is too loud past 70%. The room is 15x25. You can see in my build. Also it needs plenty of air.
bamabum is offline
post #3 of 34 Old 06-02-13, 09:55 PM
Gregr's Avatar
Greg
Re: Denon 2809
The Denon 3313ci with 125watts per should be plentyto drive 7.2 Def Tech speakers. I have the older Denon 3805 with 120watts with Focal subs and B&W satellites and I can drive at natural sounding levels with plenty to spare. You can buy Refurbs from Accessories4Less 3313ci for $629 and the 150watt 4520 for $1500. You may get a few extras in all areas of the 4520 but hardly worth the $900 extra or..., If i had the $2400 for a new Denon I'd throw a few more $$$ and buy a Krell
Regards
We believe everything we tell ourselves..., don't we??
Gregr is offline
post #4 of 34 Old 06-02-13, 10:14 PM
tonyvdb's Avatar
Tony
Re: Denon 2809
Your current Denon AVR 2809CI is a little underpowered Bench tested it will do about 95watts into two channels and it drops from there as you run more. You might just be better off investing in an external two channel amp like the Emotiva XPA 200
Home theater:
Living room system:
tonyvdb is offline
post #5 of 34 Old 06-02-13, 10:56 PM Thread Starter
Tom
Re: Denon 2809
ok. Since I am still try to learn about this audio stuff. I am running 2 front, 2 rear, and a center. Is this considered a 5 channel system that can do 7 channel? ( 2809CI ). Then my question is, 2 channel only runs 2 speakers?
tgeary00 is offline
post #6 of 34 Old 06-03-13, 08:45 AM
tonyvdb's Avatar
Tony
Re: Denon 2809
Yes , that is correct.
Home theater:
Living room system:
tonyvdb is offline
post #7 of 34 Old 06-04-13, 10:11 PM
Gregr's Avatar
Greg
Re: Denon 2809
Hey Tom,
Tony has an interesting idea, especially if you plan on growing your system and who doesn't like that idea. My thoughts and I believe Tony' as well - Denon offers Pre-amp Outs on many of their models. Now you ask, what are the pre-amp outputs and what can be the advantage.
Well on the back panel of many Denon AVR you will find RCA connectors that allow you to use the pre-amp section of the Denon amp and connect this pre-amp section of the Denon to your choice of power amps. You could buy a two channel power amp or a pair of exceptional quality monoblocks or a nice Krell 5 channel power amp or even 7 channel. This is an exceptional upgrade path.
Now with the reduced power demands on your Denon AVR power section you have greater available RMS wattage to divide between the fewer speakers being driven.
FYI - something to think about
Gregr is offline
post #8 of 34 Old 06-06-13, 11:48 PM Thread Starter
Tom
Re: Denon 2809
Thank you. I was going to ask, " how to connect an amp" thank you for your great mind reading skills. lol. The wife really does not appreciate audio like I would like her too.. So I have to keep things kinda on the down low, and sneak in a piece in here and there. And if she finds out, tell her it didn't cost much. It's ok honey. Let me show you how much better your favorite movie sounds. So I did look up the Emotiva. Looks like a great option.
tgeary00 is offline
post #9 of 34 Old 06-07-13, 03:20 PM
Gregr's Avatar
Greg
Re: Denon 2809
Hey Tom
FYI - I do not know the history of your AVR I do not know if somebody has tinkered with this Denon 2908 or 2908ci. You should not attempt any changes until you are sure you understand the process completely and accept full responsibility. I cannot know the condition of your Denon AVR and I cannot watch to be sure you make proper connections.
You will find the location of "Pre Outs" on page #20 of your owners manual with a brief description, I believe.
I understand the Emotiva equipment is nice and becoming popular. I like the prices. Hope you enjoy the results of your labor.
Enjoy
Gregr is offline
post #10 of 34 Old 06-07-13, 05:00 PM
ellisr63's Avatar
Ron
Re: Denon 2809
Gregr wrote: View Post
Regards
If you got a Krell you would then need a power amp too... I would be suprised if you could get Krell amp and processor for double the price of the Denon 4520. I am not saying the Krell is not better but that it is in a dif league. Personally if I had the kind of cash to buy Krell I would go Classe.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is online now
2809 , denon
