ANyone know if any bookshelf speaker stands like these - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 06-11-13, 12:34 PM Thread Starter
Mark Anderson
Hi All
My new SVS SB13 sub is arriving in a few days. I have a spare set of bookshelf speakers that match my existing 6 surround speakers (Rl, RR, WL, WR, SL, SR) and I'm considering replacing my floor standing with these to allow me to place my sub where a floor standing speaker was (assuming that's the best sounding position)
My floor standing ones are mirage omnisats: http://www.vanns.com/shop/Mirage-OMN...duct-542960594
My bookshelf ones are: http://www.vanns.com/shop/Mirage-OMN...duct-544250122
I have an 8ft long coffee table in front of the TV and I don't want to move it forward more than an inch or two. So I'd like to try and find a bookshelf speaker stand thats like a 3 sided rectangle (shown in blue in attached image). (I don't want wall mounted ones as it will be very difficult to run the cables. I'm hoping to build a dedicated room in next 12-18 months)
The base can be very heavy and fairly large. The key is that the vertical piece is at the back of the base, so the coffee table only need to be moved a few inches. I would consider replacing those 2 bookshelves if there with other flat to the wall speakers if they are reasonably trimbre matched an come with the appropriate stand
Any suggestions?
Regards
Mark
mark_anderson_us is offline
post #2 of 9 Old 06-11-13, 01:10 PM
tonyvdb's Avatar
Tony
Re: ANyone know if any bookshelf speaker stands like these
May I ask first what you plan to use for a centre speaker? is it the same Mirage OMNISAT V2 SS?
Home theater:
Living room system:
tonyvdb is offline
post #3 of 9 Old 06-11-13, 01:21 PM Thread Starter
Mark Anderson
tonyvdb wrote: View Post
It's the mirage center. Don't recall exact model.. Cost about $400
post #4 of 9 Old 06-11-13, 01:25 PM
tonyvdb's Avatar
Tony
Ok, just make sure that if the centre is ported that the ports are on the front not the rear or placing against the wall will not work.
Home theater:
Living room system:
tonyvdb is offline
post #5 of 9 Old 06-11-13, 01:29 PM Thread Starter
Mark Anderson
mark_anderson_us wrote: View Post
It the CC V2 center
http://www.vanns.com/shop/Mirage-OMN...duct-548399968
post #6 of 9 Old 06-11-13, 01:52 PM
tonyvdb's Avatar
Tony
Seems like its good to wall mount as it has "wall mount included". Its not so heavy have you considered getting a floating shelf to put it on?
Home theater:
Living room system:
tonyvdb is offline
post #7 of 9 Old 06-11-13, 01:59 PM Thread Starter
Mark Anderson
The center is already wall mounted. It's the bookshelves I'm trying to solve and I can't run the wires in the wall at those particular locations
post #8 of 9 Old 06-14-13, 09:42 AM
Bello has a design that has a curve in the base:
http://www.amazon.com/BellO-SP-300-F...ref=pd_sim_e_1
Seems like a perfect job for a DIY solution though. Some wood and good "L" brackets could take you a long ways.
cubiclecrusher is offline
post #9 of 9 Old 06-14-13, 12:19 PM Thread Starter
Mark Anderson
cubiclecrusher wrote: View Post
Thank's. The Bello might just do it
bookshelf , speaker , stands
