Seeking advice with Emotiva pre-amp, Emotiva amp, white van speakers and bass performance - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 16 Old 01-09-14, 06:27 PM Thread Starter
Re: Seeking advice with Emotiva pre-amp, Emotiva amp, white van speakers and bass performance
Actually, Yamaha’s professional graphic EQs are also bottom-feeders. Reasonably quiet, but don’t sound that great. Ashly is a better option, albeit a bit more pricey.
The Ashly equipment looks very nice. The only catch is my comment regarding the Emotiva equipment using RCAs. I'm kind of disappointed I bought the Emotiva equipment instead of other options, but I'm also amateur at this so maybe the amps are fine and I don't have the experience to know.
I must admit, I'm tempted to add one of these to the stack, just the RCA/XLR scenario is annoying.
bradgreens is offline
post #12 of 16 Old 01-10-14, 06:50 AM
Charlie
It seems to me like the USP-1 is the opposite of what you need for this application.
I would return it and go with an AVR that has pre-amp outputs.
That will give you the ability to EQ however you want.
http://www.accessories4less.com/make...specifications
This has a front L/R and subwoofer preout available so you can use your amp.
IMO much more versatile than the USP-1 as long as you do not need turn table capability.
chashint is offline
post #13 of 16 Old 01-10-14, 07:48 PM Thread Starter
Nice, this is quite helpful as well. I knew I screwed up in some fashion when I set up the new equipment. I'll look into it.
post #14 of 16 Old 01-11-14, 01:18 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
bradgreens wrote: View Post
The one thing I found odd which would be nice to get any detail on is that this Emotiva equipment mostly uses RCAs. I say that's odd because it looks like modern equipment uses XLRs these days, including all of the high-end graphic EQs I looked at. So if I wanted to add a graphic EQ to the stack I would need RCA-to-male-XLRs and RCA-to-female-XLRs. Is Emotiva making a mistake? Adding an EQ feels like a nuisance with this equipment stack.
I don’t know of any modern consumer equipment that uses XLRs except for higher-end pre-amp/processors, so I guess you could argue that Emotiva is “behind the curve” in that department (I expect that any “high end” graphic EQs you looked are professional equipment like the Ashly and Yamaha, so you really can’t legitimately compare them to consumer equipment in that regard).
However, since our source components are not balanced, it could be argued that converting the signals to balanced is just unnecessary clutter in the signal chain, since balanced signal runs don’t offer any advantage in most domestic installations. So I really don’t see where Emotiva is making a mistake by not including balanced outputs, except for the “keeping up with the Jones's” factor. Since that obviously matters, it might behoove Emotiva to offer an explanation on their website why they chose to not include XLRs, for the benefit of those who don’t know any better. RCA to XLR cables aren't a big deal - you can get them at Monoprice or any local guitar shop.
If you previously got all the bass you wanted with these speakers, but now you don’t, the reason most likely is that you now have them set up in a much larger room than before.
As Jim suggested, if your main interest is pounding bass, you should get a subwoofer. It matters not that your speakers have 12” woofers; they are not designed for true low frequency response. The fact that it required an artificial boost from an equalizer to get the lows you were after proves it.
post #15 of 16 Old 01-13-14, 08:57 PM Thread Starter
I have learned much from your comments @Wayne. I've been out of the home audio circle for a decade and am figuring out how some of the new tech available fits together. I appreciate your notes regarding consumer equipment which is in fact my application.
This is actually true as well. Although on first set up with the new equipment, just watching the distance in the woofer vibration was enough to see these speakers do not consume the bass by default - they need it forced via EQ as you describe, and I previously had done.
So as it is, I'm going to try an A/V pre-amp with a [hopefully] good EQ built-in (Emotiva UMC-200 matches the current equipment stack). It was dumb for me to not begin with an AVR component, I didn't realize I have 3 HDMI devices ready to plug in to one. I'm feeling very rusty in the Home Theatre department.
No doubt, my next move would be to seek speakers and a sub that compliment the equipment I've been putting together.... or find that I've failed and swap it out for other options
Cheers!
post #16 of 16 Old 01-13-14, 09:18 PM
Good luck with your project, Brad.
advice , amp , bass , emotiva , performance , preamp , seeking , speakers , van , white
