Dayton IB385-8 15" sound quality? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 38 Old 08-07-11, 12:41 PM
Moonfly's Avatar
Re: Dayton IB385-8 15" sound quality?
2 x 18 will generally be equal to 2 x 15 between drivers from the same range. The difference is usually in the Vas of the drivers, meaning different space requirements, and typically from what I have seen 2 x 15 will still work in a smaller cab that 2 x 18. As ever, same results from smaller cab drives up cost. Where the 4 x 15 will excel is in power handling, as the system can take twice the power giving theoretically more max spl, dependant on the frequency you want to drop to.
Personally, I would go 4x15 in a pair of dual opposed manifolds.
Moonfly is offline
post #12 of 38 Old 08-07-11, 05:12 PM Thread Starter
Glenn
I am going to try 4-15" drivers in one box which will be centered directly above my front 3 speakers. Amping: just for experimenting before I buy another amp, I will use my ATI AT1506 http://www.wwsp.com/ati/hometheatermagazine.htm . This is a 6ch amp that is currently bridged to power my front 3 speakers (unbridged:150w/ch....bridged:450w/ch). Now the plan is to use 3 unbridged channels for the front 3 speakers, and bridge one set to send 450w to the 4 sub drivers (all 4 drivers will share the single 450w connection).
Here's my thought process (I am no expert at the science of sound, these are conclusions that I have come to through experience and just a semi-smart guy thinking. If anyone disagrees I would like to read your thoughts.):
Why not 2-18" drivers instead of 4-15"?
I haven't done the math, but isn't there more surface area with 4-15" drivers?
Why not use 2 separate manifolds?
1)..More work, more holes in ceiling.
2)..In my experience, multiple subs in multiple locations do not smooth out the sound for multiple listening locations. The multiple distances from listening locations and multiple amping/wiring causes phase and room anomalies. Currently I am using 2 subs (in different locations) with my 2 full range main speakers and it takes hours of tweaking with Audyssey, phase controls, volume controls, and eq's to get them to play well with each other. I'm hoping using multiple drivers at a single location along with a single 450w connection will make them play together well.
Thoughts?
gdstupak is offline
post #13 of 38 Old 08-07-11, 06:57 PM
ironglen's Avatar
Glen
I'm no expert, which is why I posed the question of two manifolds vs one. Before you cut and build, I believe you can experiment to see how viable your IB location will be. Judging by your post, I think you know how to do so.
I think dual Fi 18"s have more displacement when you consider surface area and stroke compared to the four Dayton 15"s, the real conundrum is determining which setup has superior sound quality, and I don't know if anyone has an answer. I think four of the sale priced IB385's are very close in total cost to a pair of the Fi 18's, as in less than $40. I was looking at these two setups myself before putting it on the backburner...
ironglen is offline
post #14 of 38 Old 08-07-11, 09:19 PM Thread Starter
Glenn
ironglen wrote: View Post
...Before you cut and build, I believe you can experiment to see how viable your IB location will be. Judging by your post, I think you know how to do so.
Yes, I know how to do the 'sub crawl.' My 2 current subs are not in their optimal position because this is a multipurpose living room and available space is limited.
I really should do it for the ceiling placement. Time to bring in the ladder. Hopefully centered above the main speakers will yield acceptable results.
...I think dual Fi 18"s have more displacement when you consider surface area and stroke compared to the four Dayton 15"s...
I didn't think to consider stroke.
Another reason for choosing 15" drivers is that the LFE channel can have content up to 110 or 120hz (or so I've read on this forum). I believe 15" drivers would handle that better than 18" drivers (another uneducated opinion).
gdstupak is offline
post #15 of 38 Old 08-07-11, 09:47 PM
ironglen's Avatar
Glen
gdstupak wrote: View Post
I don't have a dedicated room either, that's one reason why I was interested in an IB. I hope your testing is promising .
When I modeled the two designs, the dual Fi setup could achieve greater spl (headroom), so I figured they would have less distortion for a given output, perhaps someone else can provide input regarding that hypothesis...
ironglen is offline
post #16 of 38 Old 08-07-11, 10:22 PM
ironglen's Avatar
Glen
I just reviewed the models and for identical output and freq response, the Dayton setup is at xmax (14.3mm) with 180w, while the Fi setup is loafing at 55% of its xmax (18mm of 30mm) with 300w, though it reaches xmax with 800w. You'd be looking at a difference of 112dB vs 116dB at 20hz with both limited by xmax. These occur around 15hz with only a 1st order hpf at 5hz (I use it to account for electronics loss).
ironglen is offline
post #17 of 38 Old 08-07-11, 10:25 PM Thread Starter
Glenn
When I modeled the two designs, the dual Fi setup could achieve greater spl (headroom), so I figured they would have less distortion for a given output..
I just checked again on pricing of the Fi IB3 18", for some reason I thought they were more expensive than that. Parts Express lets you ask for a discount for bulk purchases. I don't know yet if they would consider 4 drivers a 'bulk purchase' enough to lower their price cheaper than $125 per.
Rat farts, I hate it when people give me an option.
Anyone have any opinion on my thoughts as to 15" drivers being a better use than 18" because the smaller driver would have better SQ with the higher freq?
gdstupak is offline
post #18 of 38 Old 08-07-11, 10:31 PM
ironglen's Avatar
Glen
Hey! That's what my wife calls me: you haven't been impersonating me Glenn, have you?
Seriously, don't make a decision on my account. I'm sure someone else will have suggestions.
ironglen is offline
post #19 of 38 Old 08-07-11, 10:39 PM Thread Starter
Glenn
I'm guessing (never 'assume') this is a comparison of 1 on 1. So if the amount of Dayton 15" drivers is doubled over the Fi 18"er's, then maybe the 15's can handle it reasonably well.
More than likely what it will boil down to for me is if I can get a little bulk discount for buying 4 of the Daytons.
gdstupak is offline
post #20 of 38 Old 08-08-11, 07:26 AM
ironglen's Avatar
Glen
The setup's I was referring to were four Dayton's and two Fi's: sorry I wasn't more clear. Efficiency is stated to be nearly the same, it's just that the Fi's have so much more stroke-about double that of the Dayton's.
ironglen is offline
dayton ib 15 , quality , sound
