Planning an IB Build! - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 42 Old 06-05-12, 12:33 PM Thread Starter
Rmb1080p's Avatar
MoffaHoffa
Re: Planning an IB Build!
Thanks, I hope so!
Rmb1080p is offline
post #32 of 42 Old 09-10-12, 12:20 AM
Maverick
From the graphs it looks like you have your lowpass set at 80Hz? How do you get the rest of the LFE?
Any concerns with chest compressing bass? Is it still there after you got rid of your box subs?
I am planning a 4 IB318 build but I am a bit concerned about upper bass performance, since the FIs will be the only thing reproducing the LFE information.
Status: Sold!
Status: Done
Status: Sold!
Status: Sold!
atledreier is offline
post #33 of 42 Old 09-10-12, 11:15 AM Thread Starter
Rmb1080p's Avatar
MoffaHoffa
atledreier wrote: View Post
The response starts to naturally roll off a bit after 80hz so I do set the low pass to match. The other lfe comes from my mains which are JTR triple 12s, I high pass them at 60hz so I get some overlap in that area.
I get better mid-bass with the combo of JTR and IB subs than I ever did with my box subs.
Honestly though if you aren't interested in ultra low frequencies and you are looking for mid-bass headroom, I think the best idea would be a couple of THT folded horns. Problem is they take up a good bit of room and the IB as you know, eats no floors space.
From what I have found is that in order to have a really good mid-bass kick especially if you are EQd flat, you need to be pretty upwards in the volume or running the subs hot by a good bit or a combo of both.
Also do not underestimate the importance of acoustics. long Bass decay times can muddy up the tight punch we want.
The IBs sound really good and can provide very tactile low frequencies that you can feel in your gut however, there are other options that may better provide you with what you are looking for.
-RMB
Rmb1080p is offline
post #34 of 42 Old 09-10-12, 03:41 PM
Maverick
No, I love my infrasonics! I also love midbass, but my mains handle that bit. What I am concerned with is the fact that I will lose LFE information if I need to set crossover at 80Hz. Now, if it's only a natural rolloff and no nasty breakup noises I can live with it. As far as I know I have no way to let the mains handle LFE above 80Hz. Note I'm talking about the LFE channel, not redirected bass.
Also, I don't know if I'm making a storm in a glass of water here, there may not be much useful information above 80Hz in the LFE anyway.
Status: Sold!
Status: Done
Status: Sold!
Status: Sold!
post #35 of 42 Old 09-11-12, 09:40 AM Thread Starter
Rmb1080p's Avatar
MoffaHoffa
I think the redirected bass is part of the LFE signal. If the speakers can handle those frequencies at proper volumes then all should be fine.... there shouldn't be an audio/frequency hole.
A lot of receivers don't have a dedicated high pass setting option for the LFE channel so, when you set a crossover for you main speakers at 80hz I do think it automatically sets one on the lFE in that area too. I could be wrong but I think I read something about this.
So I guess the only way to pump up the 80-120hz area would be to run a dedicated EQ to the speakers.
Rmb1080p is offline
post #36 of 42 Old 09-11-12, 11:41 AM
Maverick
LFE is a dedicated channel reproduced by the subwoofer. Subwoofer also gets any redirected bass from any other channel. But with my processor (Onkyo PR-SC5508) there is no way to have any other channel reproduce any part of the LFE, unless you have no subwoofer attached.
Status: Sold!
Status: Done
Status: Sold!
Status: Sold!
post #37 of 42 Old 09-12-12, 07:38 AM Thread Starter
Rmb1080p's Avatar
MoffaHoffa
I see I see! Does your processor have a dedicated LFE Low pass setting available in the menus?
-RMB
Rmb1080p is offline
post #38 of 42 Old 09-12-12, 11:53 AM
Maverick
Rmb1080p wrote: View Post
-RMB
Yes it does. But it's been confirmed it discards anything above the lowpass setting, it will not redirect to the mains. So to get the entire LFE channel you need to have that set to 120Hz.
Status: Sold!
Status: Done
Status: Sold!
Status: Sold!
post #39 of 42 Old 09-12-12, 12:36 PM Thread Starter
Rmb1080p's Avatar
MoffaHoffa
well I'm not sure what to tell ya... I did some more experimenting with mine today and settled on running the lpf at 100hz. When I had my box subs I ran the filter higher and could never notice that much difference, I'm not quite sure how much 100-120 signal is mixed into the lfe channel, but I know it IS spec. I have not felt I've been missing any lfe since my IB subs and my favorite thing about them is not taking up the floor space. If I did it all over again though, I would go Horn and figure a way to have the mouth venting into the room much like the IB.
-RMB
Rmb1080p is offline
post #40 of 42 Old 09-13-12, 09:43 AM
Why would you go horn over IB now? Less cost? Just curious because I've been considering both.
Mattcc22 is offline
build , ib , planning
