4 X Fi IB18's infinite baffle, still deciding? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 18 Old 09-23-12, 11:52 PM Thread Starter
Dave
So as everyone knows, I posted a similar question over at DIY audio, but I am just trying to get as much info from the experts as I can.
http://www.diyaudio.com/forums/subwo...le-sub-me.html
I am trying to decide if I should go the IB route.
This is what I have planned so far.
1. 4 X Fi IB18
2. 250cf of space behind the front wall.
3. The room is 22.3' long 16' wide and 7.9' high all concrete walls, ceiling and floor
4. Looking at having a system to handle the peak 105db's at frequencies as low as 15hz or even 10 hz.
Any thoughts or opinions would be greatly appreciated.
Cheers Dave
JapanDave is offline
post #2 of 18 Old 09-24-12, 12:32 AM
HTS Senior Moderator
fusseli's Avatar
Re: 4 X Fi IB18's infinite baffle, still deciding?
What do you have in mind for your manifold for your subs? I have seen pictures of a lot of creative approaches that people have taken but since yours is in the front wall (hidden behind a screen?) maybe you don't require anything fancy or creative. How do you plan on powering your subs?
fusseli is offline
post #3 of 18 Old 09-24-12, 12:43 AM Thread Starter
Dave
Something like this, only horizontally. Yes it will be hidden behind a 14 ft screen.
I plan to power the subs remotely ,preferable via two separate amps so I can eq all 4 subs individually.
post #4 of 18 Old 09-24-12, 07:28 AM
Ile
Sounds like a plan, just keep in mind you will need good support for that false wall.
Room gain from your concrete room should give much lower -3db point than below simulation. Maybe around 10-15 Hz.
Ile is offline
post #5 of 18 Old 09-24-12, 07:55 AM Thread Starter
Dave
Thanks for those graphs, I have been trying to get winISD working all day with no success. The false wall is extremely well braced using 2" X 4"'s at a 6" spacing with 1" of MDF over that. I will have to sort the baffle out though, but that should not be a problem.
Looking at those graphs it would be hard to say no to doing this.
post #6 of 18 Old 09-24-12, 11:42 PM Thread Starter
Dave
Ile, what software is that you are using?
post #7 of 18 Old 09-25-12, 01:53 AM
Ile
Used Winisd pro alpha software. Four IB318 driver in 7m3 closed enclosure, pushed to their maximum linear excursion at 5 Hz (400w/driver) gives 127db output to 2pi / 1 meter.
With 2nd order HP filter at 10 Hz you can feed max 550W/driver and you get 2-3 db more output for upper bass, but you lose -11 db at 5Hz.
I have just two of those drivers in my small room, but those seem to be more than enough.
If you tested winisd in Windows 7, that could cause your problems.
http://www.linearteam.org/forum/viewtopic.php?t=2&p=2
Ile is offline
post #8 of 18 Old 09-25-12, 06:02 AM Thread Starter
Dave
Ile wrote: View Post
I don't need upperbase as much, as I will be probably crossing at 55-60 hz depending on how they measure after installation. So I would prefer to have to headroom for the extra low frequencies. I am not a SPL freak, I just want good clean bass down as low as I can get up cinema reference levels (Standard dynamic range of up 115db) But, I don't always watch movies at reference, I can find it too loud at times.
I tried to use the non pro winISD, but I could not get the specs of the drivers right. And I am on Windows 7.
I wanted to see how the 4 X Licars 18"s would stack up against the 4 X AE IB15"s
BTW, nice thread, looks like a nice room!
post #9 of 18 Old 09-25-12, 07:03 AM
Ile
JapanDave wrote: View Post
There is certain order to fill specs to sheet. Qes, Qms, Fs, vas, Mms, BL, xmax and Pe. Software calculate others.
Two FI IB318 will outperform four AE by 6db, but AE's goes bit lower. (f3=17Hz vs FI 25Hz)
Shouldn't make difference in your concrete bunker, there bottom end could be too rich with f3=17Hz.
AE IB15 might be out of production, least they don't list it in store.
http://aespeakers.com/shop/catalog/index.php?cPath=30
Might be some day, if I find time to finish that room.
Ile is offline
post #10 of 18 Old 09-25-12, 07:43 PM
fusseli's Avatar
I'm not sure why you would need to EQ your subs individually, since they are all locallized to more or less the same location... then again four 18" subs really do cover some real estate. Was there are particular justification for EQing individually?
fusseli is offline
baffle , deciding , fi , ib18 , infinite
