Finished IB Projects Photos - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 46 Old 04-09-08, 04:49 PM
kingdaddy
Re: Finished IB Projects Photos
4 avalanche 18" in a 14 X 14 room with 1400 watts at 2 ohms from a Mackie amp.
kingdaddy is offline
post #12 of 46 Old 04-23-08, 03:55 PM
Tom
I have a 4 Tempest-X manifold wired for a total of ~4 ohms being driven by a NAD2200 amp switched to bridged mono rated at 700 watts continuous into 4 ohm load.
IBorBox is offline
post #13 of 46 Old 04-23-08, 05:54 PM
collo's Avatar
Collo
Nice. It looks like you have room for another one above it.....
collo is offline
post #14 of 46 Old 04-23-08, 07:27 PM
Tom
Thanks. The space above is not used because it is exposed above the TV when the TV is slid back in front of the opening. It was originally used as a closet that was for items used infrequently. It had a Bi-fold door for access. So to make the final look of the IB stealthy, I cut the door in half across and rigged up a mount to hold the upper half of the door in placer. From all practical positions in front of the TV you can not see the IB. Anyway, the output is by far more than I need.
IBorBox is offline
post #15 of 46 Old 06-05-08, 07:28 PM
mike
How are they wired? What I mean do you have them pushing inward or outward?
canaris is offline
post #16 of 46 Old 06-05-08, 08:34 PM
Tom
Not quite sure I understand your question but the voicecoils for each speaker is wired in series and then the grouping of four are wired in parallel. All speakers will be moving in or out at the same time. There is no push/pull in an IB.
IBorBox is offline
post #17 of 46 Old 06-05-08, 09:15 PM
mike
I thought in a setup like that you would have all 4 of them out of phase ...so they would move inwards first...
canaris is offline
post #18 of 46 Old 06-16-08, 12:19 PM
Chicago's Avatar
CHITOWN
IBORBOX Do you really think the output is more then you need ???LOL WHOOOOAAAAA . I think im gonna try something similar with 2 subs... But very impressed with your set up as well as the others here.
Chicago is offline
post #19 of 46 Old 06-16-08, 06:41 PM
Tom
Yes, the output is greater than I can use. I had been using a SVS PB2-ISD which honestly was more than enough. My space is approx. 3000 cu ft so whatever that means you be the judge. As with everything, one man's awesome sub is another man's Kazoo!
IBorBox is offline
post #20 of 46 Old 06-17-08, 08:55 AM
kingdaddy
Chicago wrote: View Post
Thats a very common setup for an IB, relize it takes more then a typical box sub to get the same output.
finished , ib , photos , projects
