-   IB - Infinite Baffle Subwoofer Build Projects (https://www.hometheatershack.com/forums/ib-infinite-baffle-subwoofer-build-projects/)
-   -   2 -si 15" D2s in an IB (https://www.hometheatershack.com/forums/ib-infinite-baffle-subwoofer-build-projects/175250-2-si-15-d2s-ib.html)
cburbs 04-08-19 06:55 PM
I was told directly by SI this is possible -- convert it into an IB . How do you determine the box size for them?
Two options for placement = living room wall and off the garage or living room floor and under neath the floor.
If I do the garage I would do one box like this -
http://ibsubwoofers.x10host.com/resampledSub3.jpg
http://ibsubwoofers.x10host.com/ResampledSub4.jpg
My concern is will it vibrate the TV and on wall speakers since all 3 front speakers and TV are mounted on that wall especially if I use the garage for the IB?
I have done some reading but just trying to figure out how big my box would need to be with these subs. Any help on the above questions would be great.
