120" or 133" FIXED SCREEN?? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 4 Old 08-08-14, 06:07 PM Thread Starter
120" or 133" fixed screen, what should I buy?? Sony 55ES projector, on a Dragonfly or SI Slate screen. HT 25'x15'x9' part of a 64'x15'x9' rec room. Controlled ambient light for movies (black pit) and controlled recess lighting for DirecTV sports while playing pool, shuffleboard or air hockey. Why not the 133" vice the 120"??
Frogman is offline
post #2 of 4 Old 08-08-14, 07:18 PM
ellisr63's Avatar
Ron
Re: 120" or 133" FIXED SCREEN??
Frogman wrote: View Post
Myself... I will always go for the biggest screen I can fit in the room with speakers. I am currently on my 5th screen. Each time I have moved bigger. This time I decided to just go with the biggest one I can fit in the room even though I can't fill the whole screen. My reasoning is that as technology improves projectors keep getting better where screens are not changing with time like projectors. If you go with the biggest one you can fit, install your projector... You can then adjust the projector to whatever size you like and mask off the rest of the screen. If down the road you see a projector you would rather have that can go even bigger you don't have to spend money on a new screen... Just remove the masking panels and alter them to the new desired size. Not to mention a wider black frame tends to make the image look even better if you don't have a black wall.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (5) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, Oppo UDP-203, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #3 of 4 Old 08-09-14, 12:30 AM
ewardjr69's Avatar
I went with 119 inch screen with the 55ES because my ceilings are 7 1/2 feet ... I probably would've gone bigger if I could have but I'm estatic with my selection
ewardjr69 is offline
post #4 of 4 Old 08-09-14, 10:10 AM Thread Starter
How do you like your 55ES? Do you watch much sports from either Dish or DirecTV?
Frogman is offline
120 or 133 , fixed , screen
