Passive car eq - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 24 Old 04-03-14, 11:02 AM
Andre's Avatar
Andre
Re: Passive car eq
Ok so when you say vocals are you having a problem with hearing them or that they are muffled. If so I will suggest you change the speakers first, I see by your post you have aquired some infinity's is that just one pair for 2? You may not need thet EQ at all since your headunit does the same basic functions already
Andre is offline
post #12 of 24 Old 04-03-14, 05:22 PM Thread Starter
Two pair and they just aren't right and the car has a spot half din where a small eq will fit right in I have plenty of amp a four channel fosgate 400-4 and Phoenix gold sub amp older square hi fonics sub in a ported box that's what Iam
Working with and wS thinking that with more adjustability it would sound better
Maybe I just want
More adjustment not sure
bigalsaudio is offline
post #13 of 24 Old 04-04-14, 08:45 AM
Andre's Avatar
Andre
Re: Passive car eq
Then I believe you are going the right route, if I still doens't sound right, try adding some foam baffles behind the speakers.
Andre is offline
post #14 of 24 Old 04-04-14, 09:01 AM Thread Starter
Andre wrote: View Post
ok where does one find these baffles might put them in when I change speakers if they help main speakers are cut off about 120 hz
post #15 of 24 Old 04-04-14, 09:09 AM
Andre's Avatar
Andre
Re: Passive car eq
parts express online, but most local car audio shops would probably have them
http://www.parts-express.com/cat/wat...er-baffles/419
Andre is offline
post #16 of 24 Old 04-16-14, 07:53 PM Thread Starter
Well gang I put the infinity reference coaaxils with the little xt foam things in the front doors and wow what a difference as far as eq I will take a hard look at both of them but the difference between old pioneer co axils and new infinitys well just wow is all I can say
post #17 of 24 Old 04-17-14, 01:20 PM Thread Starter
And at this point after carefully looking at the eq I don't think it will help me as I give up all the controls on my head unit so I would actually lose a lot of control over the sub so for now it's just the head unit now if they made one that just equalized the signal it would work kinda like in the old days where u used a tape monitor loop but thanks for the help and I may take a second look at the eq suggested again thanks big al
post #18 of 24 Old 04-17-14, 02:11 PM
Re: Passive car eq
I'm glad that you've got things up and running and like how it sounds. Good luck with your search for the perfect sound.
lashlee is offline
post #19 of 24 Old 05-11-14, 09:27 PM Thread Starter
Why can't they make a eq that just adjust the sound in how ever many bands it says without spitting it into sep channels like the old radio shack home eq that went through the tape monitor loop that would b perfect if they could but I doubt that anyone does
post #20 of 24 Old 05-12-14, 05:56 AM
Plain ole user
lcaillo's Avatar
Tech Guru
Re: Passive car eq
Can you clarify what you mean?
lcaillo is offline
car , eq , passive
