Movie Formats: why are there so many? - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
post #41 of 49 Old 03-09-08, 09:27 AM Thread Starter
Blaser's Avatar
Ahmed
Send a message via MSN to Blaser
Re: Movie Formats: why are there so many?
I am waiting to see your next movie
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Blaser is offline
post #42 of 49 Old 03-09-08, 04:55 PM
Richard W. Haines's Avatar
Richard W. Haines
Thanks. I'll let you know when we're ready for release. Almost finished with the fine cut. I'm shooting some extra footage this coming Wednesday in NYC to fill in some gaps and have some extra establishing shots. Then we'll fine cut it, screen it for some more college students to get their input and off to the negative matcher. I can't do the track work until it's matched and transferred to video.
Richard W. Haines is offline
post #43 of 49 Old 04-05-08, 06:12 PM Thread Starter
Blaser's Avatar
Ahmed
For 2.35:1 movies, I found that setting the overscan of the projector to 92% is a good compromize between minimizing the black bars and not losing so much of the picture width.
Any thoughts?
ASME AI
Blaser is offline
post #44 of 49 Old 04-05-08, 08:08 PM
Richard W. Haines
blaser,
Well my thoughts is if you're really bothered by the black bars, go ahead. In my case I have
the image fill the screen and keep the black borders off of it. I have side screen masking for
1.33 and 1.85 but otherwide 2.35 fills the 10 foot wide screen. The extra black is masked off
in my projection porthole window but as I mentioned I have a screening room that was designed
to show 35mm on a projector which is the format of my features. I adapted it to include the
DLP below the 35mm lens. So the projected image of both 35mm and DLP is shown through
a window that can be maske off to remove unwanted black borders.
The other concern for me is seeing exactly what the filmmaker intended. I wouldn't want
to crop any of the image.
post #45 of 49 Old 05-21-08, 05:24 PM
Joe D
Blaser wrote: View Post
I have noticed in movies I recently watched that even 2.35:1 ratios do not appear much smaller than 16:9 movies. I am talking relatively here. I noted that zooming in of caracters' faces is aggressively used, propably more than 16:9 movies.
Indeed in "underworld" which appears to be wider than 2.35:1 uses many shots with the height of the screen showing only from right above the eyes down to the chin. While the screen itself is smaller than 1.78:1, I didn't feel the picture of this movie is smaller than say "monsters INC". Is this a general technique that is used with wider formats?
Moreover, I would like to extend our discussion not only to formats, but other aspects of movies (exposure, photography, direction...and so on). I may ask the mods to edit this thread title not to be off-topic.
I am quoting below what you said somewhere else:
Pls tell us more...
Blaser,
You are correct, in that Underworld was shot in 2.40:1 aspect ratio resulting in a wider format than 2.35:1.
Joe D
phat03 is offline
post #46 of 49 Old 05-21-08, 11:59 PM
This thread has been stuck...
Sonnie is offline
post #47 of 49 Old 05-22-08, 03:27 AM
Richard W. Haines
phat03,
Actually 2.40 is the same format as 2.35. The reason for the slight difference is because
technically 2.40 is the correct ratio in many cases for a film shot in 2.35 for theaters. For
Panavision and CinemaScope films, you would see the very thin cement splice on the bottom
of the frame of the negative on each cut if you actually played them in 2.35 so they crop
it slightly to 2.40. However, this extra cropping is not necessary in Technirama or Super
35 widescreen films. In the case of Technirama, the film is shot horizontally so the negative
splice is on the side of the film which is masked off by the optical track. Super 35 films are
shot full frame (1.33) and then cropped to 2.35 so you wouldn't see the negative splice and
you could play it 2.35. Some distributors just crop all scope films to 2.40 so they are consistent.
In general, people still refer to scope films as 2.35 which is the ratio they were composed for
from 1955 to the present even though they weren't projected that way in many theaters.
post #48 of 49 Old 10-31-08, 10:15 PM
Chris
Just read this thread for the first time, and wanted to say thank you to Richard. Lots of great info. And to all who asked questions.
One exception to your dislike of rear screen projection, I hope, is "Airplane!" I loved the effect in that movie, as it was so obviously intentional, just like showing the jet and having the prop sound.
tenzip is offline
post #49 of 49 Old 11-02-08, 04:13 AM
Richard W. Haines
You're welcome.
Naturally if they're spoofing rear screen projection I have no problem
with it. But it was certainly one of those techniques used in the past
that took you out of the 'illusion' of reality a movie is supposed to
generate and made it obvious it was artificial.
formats , movie
