Power Button Codes - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 02-14-10, 04:27 PM Thread Starter
yohoyoho's Avatar
yohoyoho
Power Button Codes
Philips 60PP9202
I replaced IC's and reistors plus new coolant.
Put it all back together and all I get is...........the power button flashes red 9 times then pauses then flashes red 9 times then pauses
again and again. Any help would be appreciated. thanks
Philips 60PP9202
yohoyoho is offline
post #2 of 8 Old 02-14-10, 07:42 PM
Plain ole user
lcaillo's Avatar
Tech Guru
Re: Power Button Codes
Is this the same symptom that you had previously?
lcaillo is offline
post #3 of 8 Old 02-14-10, 10:31 PM Thread Starter
yohoyoho's Avatar
yohoyoho
Philips 60PP9202
aw tore dat thing apart
then replaced both stk392-120 IC's and resistors 3149-3160 plus new coolant.
aw put dat thing all back tagether and all aw get is...........the power button flashes red 9 times then pauses then flashes red 9 times then pauses. it duz this over an over agin
any help would be assuredly appreciated. thanks
Philips 60PP9202
yohoyoho is offline
post #4 of 8 Old 02-15-10, 06:36 AM
Plain ole user
lcaillo's Avatar
Tech Guru
You have still not answered my question. Is the symptom the same as before you did the work?
lcaillo is offline
post #5 of 8 Old 02-15-10, 10:06 AM Thread Starter
yohoyoho's Avatar
yohoyoho
No it wasn't.
yohoyoho is offline
post #6 of 8 Old 02-15-10, 11:16 AM
Plain ole user
lcaillo's Avatar
Tech Guru
Then, obviously, something you did is likely what changed the symptom. Go over your connections, check to be sure you did not blow any fuses, and see what is different since you serviced the set.
lcaillo is offline
post #7 of 8 Old 02-15-10, 01:34 PM Thread Starter
yohoyoho's Avatar
yohoyoho
thank you
yohoyoho is offline
post #8 of 8 Old 03-31-10, 03:08 AM
Steve
Hi,
I dunno if your unit is the same as ours, we have a 51" 51mp392h/17 and we had the same problem - it turned out to be a touchy ribbon cable on the SSB board, which is one of three stand up boards on the circuit board that has the convergence chips. I posted a note about our unit and a couple pics on what the problem was - check it out, hope it helps ya!
Steve
SLR_65 is offline
convergence , philips 60pp9202
