SoundSplinter RL-P15 build - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
post #71 of 123 Old 02-20-09, 12:45 PM Thread Starter
lgl
Re: SoundSplinter RL-P15 build
This is the top-cap, or the enginehood as i like to call it. it`s 4 layers 19 mm MDF and one support for the damping.
This is how it`s assambled, the dampingmaterial is a high density 100 mm fiberboard made for basstraps, not sure how it will work in the tube.
Inside the tube
The tube assambled with the top-cap, the port mouth is not ready yet
lglura is offline
post #72 of 123 Old 02-20-09, 01:03 PM
Maverick
Looks good!
You sure take your time..
Status: Sold!
Status: Done
Status: Sold!
Status: Sold!
atledreier is offline
post #73 of 123 Old 02-21-09, 05:09 AM Thread Starter
lgl
atledreier wrote: View Post
Looks good!
Yes it did take more time than planed , but the end is near . I`ll paint the top-cap and cover the tube with fabrics next week.
lglura is offline
post #74 of 123 Old 02-21-09, 12:11 PM
salvasol's Avatar
David
lglura wrote: View Post
Are you planning to use any absorbing material inside the tube???...If you do, remove the wax layer before aplying any glue (I used the pink stuff and learned the hard way)
salvasol is offline
post #75 of 123 Old 02-21-09, 02:37 PM Thread Starter
lgl
salvasol wrote: View Post
I did not planned to use any absorbingmaterial inside the tubewalls, but i use a 4" in the top-cap designed for bass-traps. did study some theory about damping and i am not sure how big difference it will make. I tried to move the wax layer and it was not easy, did grind the tube inside with sandpaper. Outside the tube i did erasure with a knife and grind it with sandpaper, i realy hope the glue is fixed properly. I dont like to learne the hard way this time, used to many hour on this build.
Anyway thanks for your reply
lglura is offline
post #76 of 123 Old 02-21-09, 03:04 PM
salvasol's Avatar
David
I tried to move the wax layer and it was not easy, did grind the tube inside with sandpaper. Outside the tube i did erasure with a knife and grind it with sandpaper...
Sandpaper is not enough (I used a sander too); what I endup doing was to remove the layer completely (tube is made from thin layers of paper).
Good luck ...I'll wait for the finished product pictures
salvasol is offline
post #77 of 123 Old 02-21-09, 03:43 PM Thread Starter
lgl
Thanks a lot salvasol, i`ll remove the first layer before assambling the tube to the bottom-cap. Its to late to do anything with the top-cap. I`ll post pics to you all, i realy looking forward to finish this subs, and hope this babyes rock my house
lglura is offline
post #78 of 123 Old 02-23-09, 01:44 AM Thread Starter
lgl
This is the tube assambled on the bottom-cap, more pics when i have cover the tube with fabrics.SoundSplinter RL-P15 build-sub2-008.jpg
lglura is offline
post #79 of 123 Old 02-23-09, 01:48 AM
Mathias
Wow! It sure looks amazing. Could we get a size comparison with a person standing next to the tube?
Did you try it yet?
fackamato is offline
post #80 of 123 Old 02-23-09, 01:01 PM
salvasol's Avatar
David
Looks nice ...and I'm sure it will look better after you attach the fabric
salvasol is offline
build , rl-p15 , sonosplinter
