Shiva-x build for noob's first - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
post #61 of 105 Old 04-15-09, 03:20 PM
BigPines
Re: Shiva-x build for noob's first
Just for kicks, I tried to push the tune down to 17Hz with medium fill and you don't have enough depth in the cabinet for that anyway as the port then exceeds 26". Like I said, just build it with a port length somewhere in the realm of 20" to 23" and you will be happy!
Keep us updated!
Mike
BigPines is offline
post #62 of 105 Old 04-15-09, 03:26 PM Thread Starter
rudy
will do. i am hoping to begin some progress on the build this evening. my wife is even beginning to ask if i am ever going to get "that thing" done. thanks again for your help Mike!
mlkmgr is offline
post #63 of 105 Old 04-15-09, 03:33 PM
BigPines
Oh no, when the wife calls your new sub "that thing", it is never good. Trust me on this.
Better get busy.
Mike
BigPines is offline
post #64 of 105 Old 04-15-09, 05:16 PM
BigPines
FYI, based on the following post: http://www.hometheatershack.com/foru...tml#post162455 1 lb per sq.ft is 100% fill.
If this is true, with your cabinet's internal volume of 6.8 cu.ft, that would equate to approximately 109 oz of fill for 100% so 50 oz is only 50% fill or probably considered "typical" like we thought.
Mike
BigPines is offline
post #65 of 105 Old 04-20-09, 06:49 PM Thread Starter
rudy
i started to piece the monster together, but had to leave for a conference in SD for most of the week. crazy, after 8.5 hour drive, i was still thinking about the half assembled box sitting in my basement!! OCD...
after beginning assembling, i realize some newb mistakes were made. i should have designed the box to be assembled in a different manner and i should have measured the width of the mdf before making cuts. second sheet i purchased was over 3/4" and threw some of the alignment of the other pieces off. i took some typical pics of assembly. clamps, make shift ways to compress the mdf together--ie:weight plates and dumbbells. i will post the pics when i get back home and get the sub finished.
as far as poly-fill is concerned, can i just pick up a pillow or two from wal-mart? any particular one, or is it just based on weight? i assume i remove the plastic wrapper? (probably obvious, but i have to ask!! LOL) finally, is there a better place to stuff the pillows over another? this is going to drive me crazy knowing it is just waiting at home....
mlkmgr is offline
post #66 of 105 Old 04-20-09, 07:17 PM
Kevin
mlkmgr wrote: View Post
You can use pillows, remove the plastic. Base it on weight and you don't necessarily have to have the exact amount. I few ounces here nor there will make much difference.
Kevin Haskins
Exodus Audio
Kevin Haskins is offline
post #67 of 105 Old 04-23-09, 08:29 PM Thread Starter
rudy
about how many pillows will this equate to? and what type of pillow? i believe there are multiple varieties of pillows and none state the weight of pillow.
mlkmgr is offline
post #68 of 105 Old 04-23-09, 09:12 PM Thread Starter
rudy
and based upon my design, where would the best spot to place a pillow or two? should i just let them rest in there or should i use some type of adhesive to secure them? thanks again.....
mlkmgr is offline
post #69 of 105 Old 04-25-09, 01:46 PM Thread Starter
rudy
i found 20oz poly-fill bags at walmart for $2.67. cheaper than the pillows i had already purchased. i am going to stuff, seal and fire the sub up this afternoon. will post back results later.
mlkmgr is offline
post #70 of 105 Old 04-25-09, 03:32 PM Thread Starter
rudy
i got my camera to transfer pics finally. here is what i have to date. working on it here as soon as i finish posting. this is my first build so please don't laugh!!!
***i used my dremel to round over the edge of the slot port. no router or i would have used that.***
i will post some more pics once i get the sub completed.
mlkmgr is offline
build , noob's , shiva-x
