Shiva X Extended Bass Shelf - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 52 Old 05-02-09, 12:07 AM Thread Starter
robbo266317's Avatar
bigbadbill
Re: Shiva X Extended Bass Shelf
The wife came home and said "it looks like an oversized waterheater. You can put it back in the shed" .....
robbo266317 is offline
post #32 of 52 Old 05-02-09, 08:01 AM
Mike P.'s Avatar
Mike
Looking good, I like the color!
We're all in this together!
Mike P. is offline
post #33 of 52 Old 05-02-09, 10:21 AM
Kevin
robbo266317 wrote: View Post
The wife came home and said "it looks like an over sized water heater. You can put it back in the shed" .....
It would be a skinny water heater. The overall design looks great. Wives are predicable though. They don't like too many things that are large and odd-looking in their living room.
Kevin Haskins
Exodus Audio
Kevin Haskins is offline
post #34 of 52 Old 05-02-09, 05:28 PM Thread Starter
bigbadbill
Kevin Haskins wrote: View Post
Kevin Haskins
Exodus Audio
Are you having a go at me?
post #35 of 52 Old 05-03-09, 12:13 PM
SteveCallas's Avatar
Steve
If I have this right, you didn't get a single piece tube, but bended a couple sheets of laminate around the circular bracing? If that's the case, I hope the edges of the laminate are sealed extremely well.....it wouldn't be cool to go to all that work and then end up with air leaks, ruining the tuning and output
SteveCallas is offline
post #36 of 52 Old 05-03-09, 04:51 PM Thread Starter
bigbadbill
SteveCallas wrote: View Post
That's right. Three seperate pieces glued and screwed to the braces and endcaps.
I ran a bead of liquid nails down the lengths of the legs before forcing each piece in.
After it was alltogether I then ran a bead of "No More Gaps" down the outside of the legs were the panels slot in and around top and bottom endcaps. Probably overkill but better to be sure.
Now I just have to figure out why my Pioneer isn't outputting the sub signal.
post #37 of 52 Old 05-08-09, 08:51 PM Thread Starter
bigbadbill
I still haven't sorted the problem eith the Sub out signal.
Here is a graph of the speaker at the listening position.
post #38 of 52 Old 05-09-09, 05:53 PM Thread Starter
bigbadbill
For comparison here is the mains only and the Shiva superimposed on the one graph.
post #39 of 52 Old 05-10-09, 04:15 AM Thread Starter
bigbadbill
Now that I have a signal on the sub out I watched Master & Commander again.
Some of the cannon shots had the couch vibrating. Very impressive for a single twelve inch driver.
I will have to match the levels and check I have the phase right and measure the port output to check it is as designed.
Thanks to all who helped, specially MikeP for design confirmation and help.
post #40 of 52 Old 05-10-09, 04:37 AM
Mike P.'s Avatar
Mike
Glad to hear you're enjoying the sub.
Mike P. is offline
bass , extended , shelf , shiva
