Shiva-X 200L (~7 ft^3) build thread - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 103 Old 11-05-09, 02:40 PM
Regnar
Re: Shiva-X 200L (~7 ft^3) build thread
I did a Sketchup Drawing of your build. If you would like to use it or if other want to you can check it out in the 3d warehouse under Shiva Sono Sub. I would post a link but havent made it to 5 post yet
I also tried out heating up the pvc. It likes to bounce back to it original form. I also had to use a propane torch for it to actually bend back on its self. First try was a complete failure, I just burnt it to a crisp. The second try turned out much better but..... it also came out of round. I would stick something down the center of the pvc to keep it round as you are forming the flare. It might be just as simple if not quicker to make it out of wood. Just need the right router bit and account for the space that it will take up.
Looking good so far.
Regnar2 is offline
post #22 of 103 Old 11-05-09, 03:44 PM
robbo266317's Avatar
bigbadbill
Hi Regnar,
Check this site it will show how to get almost perfect flares on pvc:-
http://www.subwoofer-builder.com/flares-25mm.htm
Silence is golden but duct tape is silver.
DIY completed:
robbo266317 is offline
post #23 of 103 Old 11-05-09, 03:55 PM
Regnar
[QUOTE=robbo266317;203668]
Just goes to show my Google-Fu is not up to par. Thanks for the link!
Regnar2 is offline
post #24 of 103 Old 11-05-09, 05:58 PM Thread Starter
favelle
Regnar2 wrote: View Post
Cool! Thanks man. Love the modelling....that's pretty much what its going to look like! Amazing.
favelle is offline
post #25 of 103 Old 11-06-09, 03:57 AM Thread Starter
favelle
Gluing the flange for the inside end of the port tonight.
Here it is pressing on, displacing all the caulking I put on:
And the other side being sealed with the same caulking.....air leaks will NOT be tolerated!
favelle is offline
post #26 of 103 Old 11-06-09, 04:02 AM Thread Starter
favelle
The portside endcaps that go IN the sonotube were dry today, so I fit them onto the port. The final endcap that resides outside the sonotube will be fit on to the exposed port and then glued to the other endcaps as soon as I sand and paint it. I figured that would be easier to do separately. Same with the driver endcaps....
And sealing the other side. I like this caulking because it cures clear. So that way you know when its dry.
This caulking also feels quite viscous. After applying, it makes a great seal just by running your finger along it.
favelle is offline
post #27 of 103 Old 11-06-09, 04:19 AM
Mike P.'s Avatar
Mike
Looking at the tube height of the sub, it appears it is tall enough to cause a resonance issue at about 105 hz. This can be dealt with by packing in 4-6 inches of fiberglass insulation on the inside of the top cap. Make sure it's well secured, you don't want it to eventually fall down and cover the sub.
We're all in this together!
Mike P. is offline
post #28 of 103 Old 11-06-09, 04:25 AM Thread Starter
favelle
Mike P. wrote: View Post
I was thinking actually about screwing it down with giant washers or something.....
Will this even produce 105hz? The guy's receiver is set for an 80hz crossover...
favelle is offline
post #29 of 103 Old 11-06-09, 05:13 AM
Mike P.'s Avatar
Mike
80 hz isn't a brick wall, there will still be output at 100 hz.
Mike P. is offline
post #30 of 103 Old 11-06-09, 05:17 AM Thread Starter
favelle
Good to know.....
favelle is offline
200l , build , ft^3) , shiva-x , thread
