Shiva-X 200L (~7 ft^3) build thread - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 103 Old 11-06-09, 05:31 AM
Mike P.'s Avatar
Mike
Re: Shiva-X 200L (~7 ft^3) build thread
I was thinking actually about screwing it down with giant washers or something.....
Cover it with some window screen first.
We're all in this together!
Mike P. is offline
post #32 of 103 Old 11-06-09, 06:04 AM Thread Starter
favelle
Mike P. wrote: View Post
Like the nylon mesh-type stuff? I got loads of that sitting around here as well....
favelle is offline
post #33 of 103 Old 11-06-09, 10:07 AM
Mike P.'s Avatar
Mike
That will do fine.
Mike P. is offline
post #34 of 103 Old 11-06-09, 12:22 PM Thread Starter
favelle
That will do fine.
...even easier way to attach it.....use the port. I'm wrapping the port anyways. Well just add more layers to the top 6 inches until it hits the sides of the sonotube! Tie it with string or whatever...it shouldn't move.
favelle is offline
post #35 of 103 Old 11-06-09, 08:20 PM Thread Starter
favelle
Got a lot done today. Assembled the final endcap on to the port-side assembly. Sealed around the edges with caulking...starting to take shape.
Also managed to piece together the driver side endcaps. These circles are ridiculously round for being hanf-cut with a jig saw. Broke my flute-bit for my router and I figured I had a steady enough hand.....more dumb luck than anything. With the sanding, these are basically perfectly round to the naked eye:
Also sealed the whole inside with caulking. I figured this would make a nice natural gasket when its fully-dried....no chances of any air leaks from what I can see! Should be ready for final sanding on Sunday and then maybe some painting!
favelle is offline
post #36 of 103 Old 11-06-09, 08:24 PM Thread Starter
favelle
Also cut and sanded the driver protection base plate. Attached the legs and this should also be good for painting this Sunday!
Here with the legs just standing in place:
Screwed them in and counter-sunk the screws on the other side. That's the side that will be on the floor, and it will also have a big felt pad cut out and stuck to it.
favelle is offline
post #37 of 103 Old 11-06-09, 08:41 PM Thread Starter
favelle
Two questions:
1) For the dampening material, I see people use egg-crate mattress. Does it have to have those bumps on it? Do they serve a purpose? I have foamy mattress made from the EXACT same material, but its smooth. Is that ok?
2) For wiring the Shiva-X driver to the binding posts, can I use 16AWG wire? Its only going to be 9 inches in length, is this ok?
favelle is offline
post #38 of 103 Old 11-06-09, 08:59 PM
Mike P.'s Avatar
Mike
1. Not for the top end cap. You'll need fiberglass insulation that been packed down so it's 4-6 inches thick. You can use the foam mattress pad to line the sides as long as it's open cell foam.
2. 16 gauge seems a little light to me. I wouldn't go smaller then 12 gauge.
Mike P. is offline
post #39 of 103 Old 11-06-09, 09:11 PM Thread Starter
favelle
Can I use 12/2 electricians wire, or does it have to be special speaker wire only?
favelle is offline
post #40 of 103 Old 11-07-09, 11:39 AM
Mathias
favelle wrote: View Post
Copper wire is copper wire
fackamato is offline
200l , build , ft^3) , shiva-x , thread
