Shiva-X 200L (~7 ft^3) build thread - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
post #61 of 103 Old 11-15-09, 07:44 PM Thread Starter
favelle
Re: Shiva-X 200L (~7 ft^3) build thread
Got the driver baseplate endcap on to the sonotub. Perfect fit, you can see some of the acrylic caulking (non acetic acid cure) gooping out:
I don't have any 6-foot clamps, so this was used as weight to keep the endcap in place. Also heavily caulked the outside seam.....air leaks will not be tolerated!!
Lots of dust and needs to be cleaned, but side shot of the driver and the counter-sunk binding posts:
favelle is offline
post #62 of 103 Old 11-16-09, 09:44 AM
Raven
A Quick tip for anyone reading this (since the OP has already done the gluing).
An inexpensive "reversible" clamp like this can be used to PRESS panels/parts together.
Looking at Favelle's photos, he's so close to the basement ceiling, I'd have used clamps reversed to press from the 2X12s above downward. A scissors jack from a car would also make a good PRESS type clamp, as long as you have something to wedge the project and the clamp/press with.
The weights you used Favelle should be fine, I'm just pointing out crafty solutions since lots of people will be looking at our build threads in these forums.
Lonely Raven is offline
post #63 of 103 Old 11-18-09, 08:34 PM Thread Starter
favelle
Ok, its done! For the most part. A few more cosmetic things need to be done but my friend can do that when it gets to his house.
Running some test tones right now. Got some major EQ to do....Sound is LOUD! Is it normal to only have the amp turned to like 3 or 4?
favelle is offline
post #64 of 103 Old 11-18-09, 10:17 PM
Mike P.'s Avatar
Mike
If you have a strong signal feeding the amp then yes.
We're all in this together!
Mike P. is offline
post #65 of 103 Old 11-18-09, 11:07 PM Thread Starter
favelle
Mike P. wrote: View Post
How do I tell? The signal is coming straight from my sound card (3.5mm to RCA).
favelle is offline
post #66 of 103 Old 11-19-09, 12:00 AM
Raven
That thing is awesome! A little taller, and a person would think it's a pillar holding up the ceiling!
post #67 of 103 Old 11-19-09, 12:20 AM Thread Starter
favelle
Lonely Raven wrote: View Post
That think is awesome! A little taller, and a person would think it's a pillar holding up the ceiling!
Ha ha I know.....it just BARELY fit through the doorway!
favelle is offline
post #68 of 103 Old 11-19-09, 12:51 AM
Mike P.'s Avatar
Mike
favelle wrote: View Post
Maybe I misunderstand what you mean by "3 or 4". On my plate amps the gain controls are in the 12 o'clock position being feed by a receiver. Using a clock scale what is your gain set at?
Mike P. is offline
post #69 of 103 Old 11-19-09, 01:08 AM Thread Starter
favelle
I guess 9:30?
favelle is offline
post #70 of 103 Old 11-19-09, 02:23 AM
Mike P.'s Avatar
Mike
Your sound card is giving the amp a fairly strong signal.
Mike P. is offline
200l , build , ft^3) , shiva-x , thread
