Shiva-X 200L (~7 ft^3) build thread - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
post #71 of 103 Old 11-19-09, 02:40 AM Thread Starter
favelle
Re: Shiva-X 200L (~7 ft^3) build thread
Mike P. wrote: View Post
Your sound card is giving the amp a fairly strong signal.
That's the part that confuses me. I thought the signal from the PC was just a signal, and the gain knob was synonomous with a "volume" knob. Was I mistaken? I figured if I was only at like 3 on the gain knob, I could have saved $175 and got the 300W amp instead?
favelle is offline
post #72 of 103 Old 11-19-09, 10:33 AM
Raven
favelle wrote: View Post
The extra headroom you have allows you to run the sub more effortlessly, and thus, less distortion (better sound).
You don't build a bridge to hold exactly what it needs to hold, you way overbuild it so you're never wanting.
Lonely Raven is offline
post #73 of 103 Old 11-19-09, 01:40 PM Thread Starter
favelle
Lonely Raven wrote: View Post
Makes sense...but does that mean with this amp, I am being clearly held back by the driver?
favelle is offline
post #74 of 103 Old 11-19-09, 02:19 PM
Mike P.'s Avatar
Mike
With this sub design and amp combination you're getting the most amount of performance for your budget.
We're all in this together!
Mike P. is offline
post #75 of 103 Old 11-19-09, 07:49 PM Thread Starter
favelle
Yeah, I guess we are. And we're not disappointed, not at all!! This thing is a BEAST. Watched the Tai Lung escape scene from the Kung Fu Panda Blu-ray and it felt like were were caving our chests in... But we definitely can't go above 3 on the gain dial on the amp. We get some weird popping sound (loud) and I don't know if that's the amp clipping or the driver bottoming out?
favelle is offline
post #76 of 103 Old 11-19-09, 08:23 PM
Pending
Kevin
Ha! Be careful once you hear loud popping noises. That is your subwoofer telling you that you are abusing it. ;-)
In terms of your volume control, you are confusing the amount of voltage gain, required to drive the amplifier with the amount of power seen by the subwoofer.
Basically.... you need a signal of a certain voltage, to drive the amplifier stage to full power. If your source, has a very robust output voltage, and/or the amplifier has a low input sensitivity (it doesn't require much power to drive) then you may have a very limited range of adjustment on the volume knob. It doesn't mean you are using less power. The position of the knob is almost meaningless because it depends on what voltage you have driving it.
Kevin Haskins
Exodus Audio
Kevin Haskins is offline
post #77 of 103 Old 11-19-09, 08:41 PM Thread Starter
favelle
Kevin Haskins wrote: View Post
Kevin Haskins
Exodus Audio
That makes perfect sense, thanks Kevin. So how do I gain more control of the sub volume? One little turn of the dial either way has a HUGE effect, so I'd rather have it at 9 o'clock and then use the volume control on the receiver/PC. Is that a smart idea?
favelle is offline
post #78 of 103 Old 11-20-09, 01:31 AM
Mike P.'s Avatar
Mike
What signal source is driving the amp? Are you using a receiver or a PC?
Mike P. is offline
post #79 of 103 Old 11-20-09, 02:05 AM Thread Starter
favelle
Right now its the PC.
favelle is offline
post #80 of 103 Old 11-20-09, 02:07 AM
Mike P.'s Avatar
Mike
You should be able to turn down the volume of the sound card, I think.
Mike P. is offline
200l , build , ft^3) , shiva-x , thread
